SOURCE: Motherboard will not start
It seems like there could be a short in the system. Check to make sure that the board is tight in the case, and that no foreign objects are causing the motherboard to short. If there is no obvious problem and the motherboard is new, I would return it as a defect.
SOURCE: get no power with intel d875pbz in rosewill tu155 case
You don't have the power switch connected where it belongs. There's one set of pins where all the front panel connections go. This information is from the manual for this board, available from Intel here.
Hope it helps. Thanks for using Fixya!
