Troy Bilt Tb70ss Gas Trimmer Logo
Posted on May 30, 2009
Troy built 4 cycle trimmer wont turn attachments -fixed?
The engin works and thr first shaft works but blower and weedtrimmer wont turn. I had similar problem for edger and made at least a temprary repair. Based on assumption that the lower (attachment) was not reaching as far inside upper coupling, I removed coupling (outer piece with red knob) and verified that the outer "pipe" was the limiting factor as to how close they connected. Then after sawing off about 1/4" of the lower attachment pipe, I moved the coupling up, drilled a new hole for the screw and it worked! My other attachments did ont have this same problem, and now they do not lock in with the push button to prevent twisting, but my string trimmer never did anyway and I don't care about the blower. Might not work for you but it did for me and it is a free fix!
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on May 31, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
4168
Points
49
You have a broken shafrt in rod
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
2answers
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
4helpful
How to change trimmer ine in tb525cs - troy built 4 cycle trimmer
You need to unscrew the black bumper button. I believe it is counter-clockwise. Mine was very tight and took a pair of channel lock pliers to loosen.
2helpful
How do I change the oil filter on my troy built 4 cycle trimmer
You do not have one. Like 4-cycle push mower engines, these are splash lubricated. They lack a full-flow/pressure oiling system. When the oil gets dirty, dump it out and refill to proper specifications. Do this every 20 hours on this trimmer and it will stay happy for a long time.
2helpful
Lost manual for troy bilt weed eater mod#tb514cs 4cycle
I didn't find that exact one either, but recently had to work on my Yard Man 4-Cycle Straight Shaft and used a Troy-Bilt manual for a similar trimmer - worked great.
If you don't find yours at this site, maybe a similar one will work. It looks like the difference is the TB525 receives attachments. If you're trying to fix something right now, here's the manual for that one until you find yours:
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/big_red_tb575ss.html
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 • Garden
2answers
Troy Built 4-cycle engine Trimmer
there should be a label stating the oil type somewhere on the engine or cap or owners manual, if not most manufacturers recomend a 30 weight oil. be sure to drain out the old stuff first.
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
