Spoiler won't move, I don't hear the motor in the mechanism
Start by checking remote switch. Test to see if there is power at the spoiler motor. If there is power getting to the motor check for bad ground. Finally remove the cable that drives the spoiler up and down and apply 12v dc to the motor. If the motor turns check to see if you can turn the cable without the motor and that the spoiler moves. I all power checks out and the spoiler won't move by turning the cable, the gearing that the cable attaches to is most likely damaged.
SOURCE: my rear spoiler wont lift automatically or
my spolier for my 996 4s wont go down, does anyone know where the manual buton?
SOURCE: Replacing front spoiler on Porsche 911-996 - how do I do it..?
If you mean the small lower lip spoiler, remove the screws from the inside edge near wheel (1 small phillips screw each side) then tug spoiler fromone end to release plastic lugs that locate spoiler into front p.u.
SOURCE: the rear spoiler on my 1995 911 porsche carrera will not retract
There is a control computer for the wing under the passenger side dash. Check to make sure the connector to this computer did not come loose.
SOURCE: car stood for over a week, unlocked via key in
Sounds like a bad battery. Do not lock or unlock the doors until you verify the battery is good. If the alarm was on when the battery went dead, you may not be able to open the bonnet to jump the battery. The 1999 Boxster does not have a red jumper post on the fuse box. You may need to hook a male-to-male cigarette lighter between the car and another car. Do not try to start the car with the cigarette lighter connect. When charged, you should be able to reset the alarm and open the bonnet. You may will need to reset your radio when the battery is replaced: http://www.a2dvoices.com/realitycheck/porsche/
