Norelco 3605 X Electric Shaver Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One of the three shaving wheels rotates very slowly
The other two seem to be fine
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 05, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5037097
Points
35540
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I have a wobble in left rear
could be bent axle but I would lean toward a bad tire. jack rear of vehicle qnd rotate tire slowly , if bearing is bad you will feel it. hold top and bottom of tire and rock, if bearing is bad you will have play or movement. rotate tire slowly and observe where is wobble is.
Why is my 07 Mitsubishi triton speedo not working?
check the signal at the sensor with a multimeter. Most have three wires, one is a 12volt feed, one is a ground and the third is the signal wire. This wire is usually only 5volts and is grounded and ungrounded by the sensor in precise timing intervals as the sensor rotates. This means that to check its operation, make sure it has the 12volt feed and the ground, then, Jack up one rear wheel and chock the rest. Select neutral and release the parking brake.
Turn the ignition on BUT DONT START THE ENGINE. Reconnect ALL the wires to the sensor and then backprobe the signal wire you found earlier with a multimeter. Once you have the wire probed, slowly rotate the wheel by hand. The meter should show the 5 volt drop to nothing, then back to 5volts, then nothing, then 5volts and on and on as long as you rotate the wheel. If this 5volt is not present, check the instrument cluster as this 5volts comes from the speedo head. If the 12 volts is not present, check all fuses WITH A TEST PROBE - looking at the fuse is not enough and check the wiring to the sensor. If the ground is missing, check the earth point on the chassis under the rear of the cab and under the bonnet and repair and issues found.If all these tests show good and you have the alternating 5volt voltage, check the same signal wire at the cluster, if it still alternates when you turn the wheel by hand, repair the speedo head. If the 5volt signal feed from the speedo head is missing, check the wiring to the speedo head, if the signal is not present at the speedo head, repair the speedo head.
Hi, we have a Merc B200 cdi manual with 50k on with full service history. whilst driving there was an knocking rumbling sound and feel through the steering. This got worse until we lost all drive ? the car...
Sounds like you have stripped splines, damaged CV joint or popped axle retaining clip. jack one wheel at time, run slowly in drive with brakes off. the offending wheel will not rotate but axle will. if gearbox/diff axle should not rotate.
What is a rotary shaver?
Electric rotary shavers use a cutting system based upon circular blades which rotate under a slotted head. Electric rotary shavers may contain up to three rotating heads. The heads designed to swivel with the contours of your face.
2helpful
Howling noise from 2006 ford escape when driving
That's a bad wheel bearing. If when driving and you swerve side to side and its loud one way and not the other or not as bad the other then its a wheel bearing. As for the metal shavings on the plug don't worry about it unless there are chunks of metal then you should have the rear end inspected.
1994 Chevy Astro All-wheel Drive, When driving down the road, it runs fine for a few miles at 55, then it feels like something seizes up and drags. I pull over and wait and it works fine again for a f
Have you checked/greased the U-joints? Prop up all 4 wheels, put in drive and slowly rotate the wheels, and observe anything that dramatically slows down.
When i start the car and begin to drive, the steering wheel vibrates, as i pick up speed it stops, i've had the tires rotated and balanced several times, it's fine for a while than it starts again???
These may not be your problems since it is occurring even at low speed but you might have the car just free of the ground and rotate each wheel and watch the clearance while you do it for changing clearance. This will reveal 'out-of-round' tires; it happens. Second; but less likely, I had this annoying problem of two speed ranges, around the 30 MPH and 70 MPH points causing wheel shake and it only stopped after I tossed the original brake rotors and replaced them with Brembos.
In 50+ years of driving, poor tires have happened several times and brake rotors twice. There was a feature of a now-defunct chain called 4-Day Tires that kept me going back called 'tire matching.' All replaced tires were checked and then shaved slightly to correct for roundness. With this done, I never had any loss of balance during the life of the tires. Haven't found this offered anywhere else since then; too bad.
2helpful
2answers
How to check speed sensor 2001 road king ( sensor has already been cleaned)
speed sensor is located in front of engine oil dip stick on my o1 rk,in frt of starter motor,my speedo stoped working today, and the sensor has one 7/16 bolt head easy to get to with open end wrench.remove the bolt and slowly wiggle the sensor and lift up and pull out,my sensor was coverd with metel shavings,i wiped it clean with a clean rag,a magnet is also helpful to remove shavings from sensor but the rag worked fine,put the sensor back and bolt it back in,not to tight just good and snug.it fixed my problem.speedo works great again.
1995 Prizm Horn Problem
keep the steering wheel in one spot, do not rotate,  check horn by pressing pad in different areas.  If it is intermittent then horn pad is concern.  If it works well trying slowly turning steering wheel while pressing horn pad if there is a point in turning the wheel where horn becomes inop, then the common fault is the horn contact ring inside of the steering column
2helpful
4answers
Rotating ring/ Glide tray comes off the track -Elite Model 80803
Take your round glass tray and plastic three wheeled hoop to a local Sears store, open up the microwaves on display, find the one that is still using something similar, deftly trade out yours for theirs. The new wheeled plastic hoop wheels are slightly bigger and the glass tray raised guides are a bit longer, since the switch no problems like I had. Don't get caught. They do not have those parts for sale at the local Sears store.
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
