SOURCE: need code to unlock car stereo for acura tl 99
I'm not sure if it applies to to all acuras of that same year but try this code 54151
SOURCE: Radio code needed for radio in '97 acura 2.5 tl
you need to get serial # ON RADIO and then call dealer they can look up code with correct serial #
SOURCE: I need a radio code for my 1999 acura TL.
You must contact the parts department of your local Acura dealer to get this code. You will need to show them your car's registration to prove that you are the owner. You may be able to get the code with only the registration and the VIN code (found on the registration). Some manufacturers require the serial number on the radio, which would require that the radio be removed from the car to see the serial number.
Charlie
SOURCE: cost to replace 2002 Acura 3.2 tl transmission
your car could still be under warranty depending on the miles the car have call your Acura dealer for info. I had my transmission replaced in Feb 09 and it was done for FREE!!
