OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
SOURCE: Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
SOURCE: I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
