Logitech Z-5500 Computer Speakers Logo
Posted on Oct 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No digital SoundTouch control center Logitech Z-5500
My son returned his contol center under warranty and they sent him a whole new system So I have the speakers only Got any ideas hoe i could use them or a cable/pin schematic?
Cory Kielion
Level 2:
Sergeant:
Novelist:
  • Expert 143 Answers
  • Posted on Nov 01, 2007
Cory Kielion
Expert
Level 2:
Sergeant:
Novelist:
Answers
143
Questions
0
Helped
136322
Points
516
The very same problem I ran into when I received my new ones today...
But from the get-go, I figured that I could either use the speakers in conjunction with the new set to create more sound...or use the speakers with other systems.
Keep in mind however that speakers from one system may not act or sound the same on another system.  The difference being that one set of speakers could be your standard 8-ohm speakers where another set could be...say...  4-ohm.  Typically, the less resistance a speaker has, the better quality it is and the more sound it can put out without taking damage from the higher current.  (Lower number = better.)  You can mix speakers of variable resistances if you like.  It shouldn't be a problem - UNLESS you are going to be using them at higher volumes. If that is the case then you are going to be pushing out more current through the speakers.  The lower-resistance speakers may handle it just fine...but those with higher resistance have a higher resistance for a reason.  (Normally that is because they can not take the higher wattage.)  Otherwise you may simply experience different results in sound quality.
Be aware, however....  Depending on the quality of the speakers and their manufacturer; this may not always be the case.  It is simply a general principle of electronics and a good one to work by.
Me?  Given that I now have EIGHT satellites and TWO center channels now...  I'm going to attempt putting two speakers to each channel and elevate the second one.  This should turn my office into a veritable ocean of sound!  :)
As for a cabling or pinout schematic...  You'd have to specify for what exactly.  An educated guess would tell one that you want to possibly create your own box of sorts to control the sound system.
It's probably not worth your time.  If you really wanted to, however...  You might consider creating your own very basic inbput/output system for it that would include an amp system to drive the sub and use crossovers for the satellites.  If one could figure out the internal systems of the sub-woofer, you would most likely be able to use the amp and any I/O system that is built into the sub.  That would require a bit of electronics background, a soldering iron and most likely a LOT of patience.  There is more involved in that process than I could explain here.  (I haven't even opened up my old sub yet.  Should be fun...  Looks like it just takes a hex key to the front of the sub to open.)
Whatever you do.... PLEASE be careful!  There are going to be plenty of amplifier circuits in there...and I can tell you from experience that they can give you QUITE a shock.  (Or even explode; as in one situation I experienced.)
Any more questions?  Let me know.  But that's just about it.
Cyryl
My Z5500 logitech subwoofer makes weird noises similiar to thunder, it doesn't matter is there input or not. it just makes "thunder" noices all the time and wont *******. what is wrong in it?
Most likely its broken... if its less than 3 years old, call logitech, they'll send you a whole new system for free without you having to return the old one. Just make sure you have your receipt.
The control unit is not working is it possible to buy a new control unit separately? thanks in advance. best regards morten Andersen
In short-No. However, there is a way... The Z-5500 5.1 digital system is a propietary system which basically makes it a single 'unit' to put it simply. It may be possible for you to locate a replacement Control Unit from an individual on some place like e-bay or Craigslist, but Logitech warranty will NOT replace just the control unit itself. What they will do; totally contingent on the year of manufacture as to whether your system is covered under warranty, which is 2 years, and also very very critical that you provide the correct PID # located on your Control Unit as this acts as a S/N number for the aforementioned "unit" aspect and different model revisions and updates/upgrades are all made in the same manufacturing plant to ensure compatibility amongst your individual system and ONLY the same units/speakers made in that factory under any particular version number. The information I offered you here will hopefully provide someone a heads up so you don't have to deal with the 6 week headache I went through JUSt to get the proper # for the proper department that can assist me.
1helpful
Control box for the z-5500 turns on for a few seconds with the screen full of black bars and shuts itself off
try a reset-- turn off the control pod and in stand by mode hold the source and the input bottons at the same time. firmware version should appear on the screen. the try using again. If that does not work call logitech for out of warranty discount on a new system.
2answers
Repalcement Logitech Z5500 Control Center?
My Control center turns on but i can get any sound not even from the test system, Logitech cant help.
I went the a shop and check it on ther system still no sound :(
any ideas
Contol panel
contacting the logitech su\\showroom
i will be within the warranty period
they will repair it for free
4answers
Logitech z-5500 surround.
Hello Thimo
First things First:
1) The only thing sincerely you have to do in this cases, if you yet have warranty, is RMS the speakers, for a new one, or repair.
other than this, is a internal board power for your speakers.
good luck
Open SKY
2answers
One controller pod...being split for two speaker sets?
Technically it's not a KVM connector.
A KVM switch uses a DB15 serial connector.  Just like a monitor uses a DB15 for it's VGA connection.
The pinout for the control center's DB15 connectori is not likely to be the same as either one of those two types of devices.
Unfortunately, there is no way to make one pod work with two sets of speakers. The reason for this is that the voltage supplied to the control center comes from the sub-woofer.  You can imagine having two sources of power connected to one, single control center...
The control center would not know which sub-woofer and power system to regulate.  You would end up with issues revolving around power distribution, volume levels being variable - or worse.  More than likely, you would either overload the control center or it would simply not be able to keep up with the demand for both systems simultaneously.
I myself just had my set of Z-5500's RMA'd to Logitech under the exact same circumstances.  I just received my new set today.  Retail box and everything.
He was NOT kidding you.  I had to make him repeat himself just like you did.  LOL.
But I sent the control center, remote and purchase receipt with them.
5 days later, I found out DHL almost had my package here.  (Although I was lucky.  The turn-around time on the RMA is subject to supply and demand.  I was quoted 6-8 weeks at one point due to their lot being completely empty.  They are manufactured and shipped from China according to the rep I spoke with...)
My advice to you is to get right on the RMA process.  Get your incident number from the Logitech rep who sets up your RMA.  Get those two pieces sent in as soon as you can.  Do what I did.
To do this, call the following number.
General Technical Assistance/RMA: 646-454-3200
Package the remote, control center into a box snuggly.  WRITE YOUR INCIDENT NUMBER given to you by the Logitech rep on the receipt.  Include the receipt in the box.  Take it to the post office and send it by USPS Priority mail.  Get "Delivery Confirmation" on it.  All told it came to just under $10 for me.
Send it to the following address:
Logitech Incorporated
6505 Kaiser Drive
Fremont, CA 94555
ATTN: Incident Number# <put your incident number here>
You will also be instructed to send a copy of your receipt by way of fax.  WRITE YOUR INCIDENT NUMBER AND PERSONAL INFORMATION ON IT BEFORE FAXING.  (Or at least on a cover letter.)  They're supposed to send you an email to let you know that they received the fax...but I never received one.  Good thing I included a second copy with the control center and remote...because that's the one they used for processing.
FAX: 702-269-3439
I have pics of the shipping order that came on the box, too.  If you would like to see this proof, let me know.  I'll be more than happy to post plenty of pics that show my old set (sans the control center of course...) and the new set.
But don't delay like I did.  Mine was two days away from expiration of the warranty before I sent in the parts.  LOL.
Any more questions?  Let me know.  :)
Cyryl
1helpful
2answers
Logitech 5500 Surround Sound controller
It 's not the fuse!!!! THAT fuse is only for SUB !!! if that fuse was the problem he wont have power at all.THE problem is with control center .I fix my control center changing 2 diodes ,but a friend of mine have exactly the same problem comming from some transistors with is located above that 2 diodes D700,D701(so he says) --- surf check google and you ll see a lot of customers with exactly same porblem AND THIS PROBLEM I THINK IS SOME DESIGN ERRORS THAT AREN'T FIX BY LOGITECH BEFORE SELLING THIS SYSTEM!!!!!!!!!
3answers
Digital Sound Control Center
Suggest a problem with internal power connections open up the unit a check.
3answers
The system has stopped turning on
I would connect your speaker system to another computer that has a working external sound system. If your speaker system fails to work there as well I wouldn?t waste any more time on it nor would I do anything to risk voiding the warranty. Your speaker warranty period is two years and you will want to get these exchanged as soon as possible. Even with the replacement set your warranty will still expire two years from your purchase date assuming you have your receipt. If you don?t have the receipt they can determine the manufacturing date from the serial number and will use that as the beginning of the warrantee period. Replacing them as soon as possible with give you a year to exercise them to ensure there are no hidden problems in the replacement set as well. Good luck and please don?t forget to rate this post.
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
