Hi, I have a sony vaio netbook that has a common USER profile service failed logon message. But the problem I have is that it doesn't open in safe mode hence I cant fix the problem. Any one have any idea's
this may be a corrupted file for taht particular user thats causing the problem why cant you try opening the other user profiles or if you cant access that too then try turning on your pc and when the list of user profiles appear press ctrl+alt+delete key in and order but you should keep allthree keys down like how you would keep the shift button down while typing an upper case....now when you press all three down a small dialogue box will appear requesting username and password in the username box type administrator and click login no password required after it logs in create a new profile from the control panel but don't use this user profile again because if this gets corrupted then you would have to format your computer.....formating it will delete all the data stored on your pc.....
SOURCE: L350-170 Logon Failure
Sounds like profile corruption or virus problem. Try restarting the machine and tapping f8 until menu appears. Go into safe mode then logon as administrator. If you can get into windows, go to control panel then user accounts. Create new user account then restart machine. Log on using new user account and copy all personal files/folders to new user account.
SOURCE: My VAIO (VPCX113KA), it starts OK and hit the
Your password may be wrong. To rectify it, login as administrator and from the Control Panel->User Accounts delete your account and after a reboot, create it again if you have to have some accounts.
SOURCE: I can't logon. It says User Profile Service
Use the Function key or Delete key to stop the machine from booting all the way, in other words, interrupt the normal process. You can try to use the "restore to the last successful boot" selection. If that doesn't work, you can re-install Windows.
What is happening is that windows wants to run the program to let you input the user/password selection and cannot start it. Maybe it cannot find it or the 'file got corrupted' standard Microsoft answer.
Personally, if find that a horrible excuse. Computers are not supposed to corrupt files willy-nilly.
Anyway, you likely have a hard drive dying slowly, and should back up any files you need from the machine ASAP, and then re-install windows.
tom
SOURCE: the user profile service failed
pc on after press F8 open safe mode
after restrt problem sloved
