Car starts fine in the morning and then when it warms up and turn if off it wont start until it cools down. There is no spark. It can be rolled and clutch started and seems to run fine again until it is turned off. Have changed the fuel filter and the coil pack but still having the same problem.
Either a weak battery or a defective starter. Have you checked your battery voltage when it will not crank? Cleaned your battery terminals?
If you need further help, reach me via phone at https://www.6ya.com/expert/tom_1788908372a4836f
SOURCE: s10 pickup after warming up truck starts missing
You might have computer problems.
Does the check engine light come on when it starts to miss?
SOURCE: 2000 silverado 4.8 v8 runs bad when it is cold out side.
Try replacing the coolant temperature sensor for the injection system.
SOURCE: My Hyundai Elantra 1999 crankshaft position sensor A circuit
could be ??the windings in the sensor have the insulation on the way out
SOURCE: Car starts fine..Idle is fast...stalls after car warms up
Check for vacuum leaks. Also try cleaning the ISV.
If that doesnt work go to vwvortex.com and post your issue there
SOURCE: 1996 HYUNDAI LANTRA STALLING RANDOMLY
Throttle position sensor, check that, or fuel pump/filter
