The dryer has power, will turn on and spin with cool air only. will not heat up and dry clothes. kenmore 400 series
Okay, let me try to solve this with three possible solutions:
EASY AND CHEAP: Check the hose, the lint filter and the vent for obstructions. If the air is not getting out then the safety switch in the dryer will tell the element not to heat up. Without this safety switch the dryer becomes a fire hazard (and that's a whole other FixYa problem!). Make sure the hose is not crimped or clogged and that the outside vent is opening properly.
HARDER AND MORE EXPENSIVE: The heating element may be burned out or have a loose connection. This is a little bit harder fix but can be done without consulting a repairperson. However, if you have little or no experience then don't try that at home.
EASY BUT MOST EXPENSIVE: Buy a new dryer. If you do, see if the company you buy it from will take a trade in. If not, call a small appliance repair shop and see if they would like to buy your machine to repair and resell. This might offset some of the cost of the new dryer.
Hope this helps. Good luck.
