I do not know about these items but if it works on other phones then a few things spring to mind, that moto might use a different version of plug like a "3 ring + tip" plus there maybe one with 4 + tip. Another thought is the mic needs power if its an electret type which that moto does not supply.
The connection of those earbuds may be wired a little different to how moto needs, many manufacturers do this so you buy their bits and bobs.
Lastly the moto may need some feature selection in its menu system to be turned on so look through its settings for audio-microphone etc.
Hope this might help
You have to wire the plug to eliminate the voltage sent by the sound card. I can't remember if it's the tip or the sleeve, so you'll have to verify with a volt meter. Use a 3 position plug to solder to the mic wires, just don't connect the wires of the mic to the one that has voltage on it
First, excuse my answer/question, but you are plugging mike and phones into correct ports?
I once cursed my headphones & software only to realize that I had foolishly plugged phones into the MIC jack!! :rolleyes:
I haven't seen the jack-plugs on your model, but are they separate, stereo 3-way jack for 'phones and mono 2-way jack for mike?
I'm thinking of a 4-way all-in-one phones/mic jack not matching with stereo 3-way output socket of sound-card.
Working from tip at end of jack-plug,
Mic: Tip=mono signal out, Sleeve=GND
Stereo Phones: Tip=Left in, Ring=Right in, Sleeve=Common GND
Multi: Tip=Left, Ring1=Right, Ring2=Com GND, Sleeve=Mic sig.
