Question about Encore Software Kawasaki Jet Ski Watercraft for Windows
Jet Ski Will not start when cold
I have 2 1999 Kawasaki Jet Ski 1100 STX. Both of them have the same problem. They will continuously crank and not fire up. I think its a fuel problem because i did not put stabilizer in before the winter. I cleaned out the lines and pump thing on the rear of the engine, and took out the diapram and cleaned it. If i take the cover off the 3 carbs and spray some gas I can get it to start and run fine. It will start again no problem but as soon as the engine goes cold, it won't start and I have to take the carb cover off and put more gas in. That obviously isn't a permanant solution. Any suggestions?
    President:
  • 1,978 Answers
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
Posted on Sep 05, 2010
2001 Kawasaki 1100 stx di. Had a hose hooked up to it tonight idling and reviving it up, then it started to rev up on its own for a couple of seconds. Any ideas what it might be.
You may have leaking crank seals. If they leak they can cause air to mix with the fuel before it gets to the carb, causing the motor to rev high unexpectedly.
May 17, 2017 | kawasaki 2004 Jet Ski 1200 STX-R Base
Need wiring diagram 4 1999 stx kawasaki
Hello there,
Cannot find free ones,
Go here and for Five of your American Dollars, you can get it.
http://www.selffixer.com/jet.ski/kawasaki/1999-kawasaki-stx-1100-wiring-diagram.htm
Sep 19, 2014 | Motorcycles
Need wiring diagram for kawasaki 1100 stx ignition
Hello there,
Owners manual for 2006 kawasaki 900 STX jet ski
You might want to post this question in a different section. This is the computer games section.
Jul 09, 2012 | Video Game Consoles & Games
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
Jet Ski Won't Start when Engine is cold
You must take out completely the carbs and clean them especially their canisters with the flowters.They may have jelled gas inside or closed air pipes.Use a carb cleaner spray and compressed air.
May 25, 2009 | 1990 kawasaki ZXR 750
Encore Software Kawasaki Jet Ski Watercraft for Windows Logo
1,104 people viewed this question
Top Encore Software Video Game Consoles & Games Experts
James Wishart
Are you an Encore Software Video Game Console and Game Expert? Answer questions, earn points and help others
