"I have a nissan quest 1994 one day I show a smoke near the passanger front wheel don t know what cause the Problem. i stopped for a while and draw back home the smoke wasn't much as it was. I kept parked the van for a week and took a trip for 10 mile to see whether it repeats, but not seen. Will it be a big problem. What may be the cause?
Pull off the tire and remove the rotor. clean the bearings with carb cleaner and look to see if they have signs of heat stress(dark blue/purple disscolorations) if so replace both inner and outer bearings. also look for the same discoloration on the rotor. If it has the color, your brake caliper is hanging up. It also may of been something as simple as blown grass od weeds caught in the rotor and burned off when it got hot, thus the reason you havent see it since.
