1994 Land Rover Discovery Logo
Posted on May 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All Side Light Fuses Keep Blowing On My Landrover Discovery 1994
Ive tried to fix my problem by checking all the side light bulbs and replacing all the fuses to the same if not higher ampage but still the fuses keep blowing,any ideas what to try next? thank you
ben thompson
  • benthompsonu May 21, 2009
    Marker light where and what is this? thank you for your reply!
Dar
Level 3:
President:
  • Land Rover Master 2,007 Answers
  • Posted on May 21, 2009
Dar
Land Rover Master
Level 3:
President:
Answers
2007
Questions
Helped
734589
Points
6454
Look at the wires behind your marker light, especially at the back where there are more stones hitting. You probably have a bare wire or two.
  • Dar
    Dar May 21, 2009
    Your "side" lights. The ones you're having trouble with.
  • Miranda Stewart
    Miranda Stewart Oct 27, 2018
    No the brake lights
1998 landrover discovery blows fuse #14 when shifted to reverse
You can check the reverse light bulbs and see if they are bad/corroded, also check ground wire.
1helpful
I have a 1994 Land Rover Discovery V8i, 5dr. The rear side lights in the light cluster do not work. There is a second row of lights on the bumper bar that do work. I have been told that with this model...
Hello! The 1994 models featured larger headlamps and a second set of rear lights in the bumper. The new rear lights had the wiring changed several times to meet real or expected European safety legislation. Some vehicles are left with an arrangement where the vulnerable bumper contains the only working lights. The rear side lights in the light cluster become non-operational...
Guru.......Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
1helpful
I keep getting a blown fuse belonging to the left side rear and side lights. The fuse should be 10AMP. I have tried 15 AMP and 20AMP fuses and those also blew. Any ideas? By the way, this car is a...
First put the required fuse dont go up you do more damage, For a fuse to blow you left rear side light and side light has shorted out to ground. left side rear light look at the wire are there any exposed, If no go to the side light inspect the wire are the exposed, if you see any repair it, Now if fuses keep blowing go the lamp belonging to that fuse and pull the bulb out with the bulb out an fuse installed twist the socket one at a time did the fuse blow,if it did you found the source,more than likely you ll need a bulb socket, as long as the wire are in good shape . Remeber correct fuses,No foil No nails No other Range just the required fuse
2answers
I own a 1994 3.9 v8 landrover discovery,can you tell me what the 'check engine' warning light means? the vehicle wont start. i have checked all leads,fuses,battery,starter motor. it has plenty of power in...
'Check Engine' is a general warning light telling you there is a problem somewhere on the engine. **Note** It is supposed to come on when you turn the key as it is checking the engine electronics. It should go off after a couple of seconds to show the system is working properly. If it stays on get a good auto electrician to plug it into a specialist diagnostic computer to find out where the problem is.
1helpful
2answers
Headlights dont work on dim
check the fuses really closly.
then use a test light on the dim side of the lights electrical plug.
make sure its getting power to the dim side.
maybe both dims are burt out?
keep me posted.
jm
1992 Landrover Discovery - I cannot get the ignition to turn on
look under the hood under the steering wheel their is small panel to driver side where you put your left foot take the small panel out sometime their u find fuses or to the right of the car passenger side where the passenger puts his right foot check their manufacturers like to hide the fuses
I connect a 1997 landrover discovery computer to the 1994 landrover discovery and it won't start.
if it is a mems unit , it will need to be programed to the key fob and alarm . (there is no way round it).
1995 Land Rover Discovery Tail Light Problem
Check the circuit board that the bulb plugs into and make sure it is not burned or that the contacts are not damaged.
8helpful
How do you replace headlight bulb for a 2004 landrover discovey
yes that is right the grill needs to come off. three plastic clips top front of grill
you can take the headlight out one star screw on the top and a pozzy screw to the side behind the grill it has to be poped out of the bottom of the headlight
then you can get to the back of your head lamp ok
Top Land Rover Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Land Rover Expert? Answer questions, earn points and help others
