I assume you mean the mic plug/jack. Bent pins or broken connectors will require a new jack and/or plug installed and they are not easy to do. These 3.5 mm jack connectors require both a light touch during install and soldering. If you're a pro then start shopping for a replacement 3.5 mm mono jack but be warned. The jack may solder directly to the PC board....which reminds me. Look for broken connections from jack to PC board..a common failure point and resolder as needed.
Well, there are a few ways to solve this. The easy way would be either to call the manufacturer (At
(860) 434-9190, more info here) and see if there is a warranty on the item. Second, you could just buy a new pair, which is probably not the best way. Third, you could actually splice a new jack onto the headphones with a little soldering skill. You'll need to:
1)Cut the ******** the end
2)Strip the wires off the jack (and the replacement jack)
3)Solder the wires together (Matching black to black, red to red, ground to ground, etc)
If you've never soldered before, see if you could get a friend to help. Here is a video tutorial of how to solder, if you wish to attempt this yourself.
See my tip on headphones jack/cable problems. Also sometimes they put on a special coating on the wires. You have to scrape the wire or file it to remove it. Spit is also good at making the solder stick!
Hi, Sennheiser SHOULD still service these. I'd recommend having another go.
However, i'd like to clarify which part of your system has failed. Is this the locking jack plug on the ME2 / ME4 tie clip mic. A common failure point.
Or the antenna on a beltpack (also common), or something else?
They're both fixable, the locking plugs are available to buy now from other suppliers. And the antenna are just an m3 plug with a solder bucket in the top. A HOT soldering iron, and a bit of heatshrink can repair these.
If you don't have any luck then you can contact me direct and i'd be happy to have a look for you. [email protected]
If you know how to solder wires then the cord is certainly replaceable. My cat chewed through the cord on my BeyerDynamic headphones, but I was able to order a replacement from them, take the earcups apart, remove the old leads and solder in the new cord lines.
You could try calling the customer service line for Sennheiser and see if they can send you a replacement, or you could just pick up a generic cord from Radio Shack or an electronic parts supplier.
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
IF THIS IS A STANDARD .125 90 DEGREE STEREO JACK(NOT FAMILIAR WITH SENNHEISER)THEN YOU SHOULD BE ABLE TO PICK ONE UP AT ANY LOCAL ELECTRONICS OR STERIO STORE.ITS JUST A SIMPLE MATTER OF SOLDERING IT ON.THEY SHOULD CARRY SOLDERLESS ALSO.BUT BE WARNED THESE ARE NOT PRETTY.HOPE THIS HELPS.THANX FOR USING FIX-YA.PLEASE RATE.
The standard HD25SP cable's 1/4" jack screws over the mini-jack. There's no reason for you to do any soldering. If you have a few inches of cord left from where you cut the plug off you may want to re-splice the cable back together to their corresponding colours. Then unscrew the 1/4" ******** to reveal the mini-jack.
