My best bet is that the adapter is overheating. I have seen similar issues when I used to do computer repair. As far as I know there is no easy way to fix this besides using it in a chilled environment. Um... other possible problems with the same recomended course of action are: some how a wire got lose inside, a liquid got spilled on it by somebody or something, or it sustained a jarring fall (not likely).
I would uninstall the driver by going into control panel, selecting Device Manager and finding the yellow marked driver. Click on it and remove it. When you re boot the laptop, the OS will place a fresh driver there and hopefully that one will work. If it doesn't, the WiFi board may well be faulty and a replacement may well be required. Hope that helps.
remove all attached devices like printers or flash drives. remove battery and power on using ac adapter only. if it still wont work, try another good ac adapter. make sure ac adapter light is on. if it still shows the power light on and nothing else, replace motherboard.
Try a friends computer. If that dosent work, check the ac adapter, replace is nessary. if that dosent work put the hdd in a nother enclosure, still not working, the hdd istelf will be broken, tae the drive to a data recovery centre
try plugging the usb adapter into a different usb port of the computer and there must be a connect button on tat adapter..press the connect button on tat aadapter and then press the connect button on the mouse {after replacing the battery}.if it doesnt work on 1st go ,,try 2-3 times,,,and hey best of luck
bring up hyperterminal it will open a connection window if there is a modem inyour system it will default to it select in the down arrow to the left com1.
this will open the com port window.
at which time you should select the settings accroding to your connection. bits persecond data bits flow control. all this should be within your installation instructions.
good luck
