Sounds like the igniter coil is failing or the thermocouple that holds the gas valve open after the flame starts is weak. The thermostat sensor could be bad as well.
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat. If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
There does seem to be a fault, as the fan should run continuously even when the element goes off at the required temperature setting, and the light should atay on as well.
It suggests to me that there is a fault with the oven thermostat, or it is wired incorrectly.
Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
Theres probably an adjustable gas valve on it. You should also know the igniter and gas valve being wired in series makes it sensitive to current flow so the igniter could be the problem. Low current flow would not allow the valve to fully open.
We had this problem; Your thermostat is probably broken. To test this theory, buy an oven thermometer and test how accurate the oven is. My bet is you will find this to be off. Fix it now, otherwise, it might lead to other issues.
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
