True GDM-69 Refrigerator Logo
A
Anonymous Posted on Dec 30, 2013
Need to install new ballas - True GDM-69 Refrigerator
1helpful
Have a Mitsubishi Big Screen, Model VS-5043 (AC 120V, 60H, 210W), and get no picture. I believe all I need are bulbs. Think it's worth a try to get them or should I have a repair guy get a look-see?
Hi dejjjavuu,
You have 50% chance that it is a bulb problem but you have a ballast board that supply the bulb also. The problem is, this board needs to check with an experienced technician for fault. But for me I've suspected also the bulb most especially if the unit is more than a year old, you can't test this bulb unless swap a new working bulb in the ballas board that's why you need to call an expert. However if you have a spare bulb you can swap it and try.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Left lowbeam headlight went out. Had xenon headlight replaced at nissan dealer but now they tell me there is some other problem and the light does not work. They say they need to do dianostic and wanted me...
probably has a ballas that went out. changing the lights on that product is usually a pain in the ****. but over time some ballases will go out. simple fix but they will have to test voltage until the find where the problems begins.
1helpful
Manual bella cucina bread maker
Need a Manual for a Balla Cucina Bread Maker model number XBM1018. Where can I get one?
Respond to [email protected] Thanks Joe
I just recieved a new lamp for my TV... I installed it correctly but the Tv still tries to power on, but no picture comes on and the lamp light still flashes red... What should i do, or what can i do?
It is possible that teh ballas on your tv is not working correctly, when the ballast is weak it cannot power the lamp there for you get no picture, you can go to a page called discount-merchant.com, they have a lot of good parts at good prices.
Turn LCD tv on but picture does not come on straight away - it's as though it needs to warm up - after turning on and off several times for about 5 minutes the picture comes on
it is possible that the ballas on your tv is week and not sending enough power to turn your tv set on, you may need to replace it if this is the problem, i can recoment to pay attention to any strange mechanical noises on you tv, like buzzing or clicking sounds if so you may need to replace it, I can recomend a page called discount-merchant.com for your parts
Need help to hook up wires from distibutor to the coil and ballas
call dodge parts dept give them vin # and they will fax you the schematics for this and you can keep them in your file/ Please rate this response thank you vey much
3helpful
Burning smell from microwave
This is the waveguide cover / stirrer cover.
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Please reply back with your brand and model number so we can help you in obtaining parts.
Otherwise, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
3answers
Assistance
i would try new lamp or ballast since you have 250v from pwr sup
Top True Refrigerators Experts
ZJ Limited
ZJ Limited
Ngoro
Are you a True Refrigerator Expert? Answer questions, earn points and help others
