1995 Mazda MPV Logo
p
paea fifita Posted on Dec 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why do water-tank explode
Yesterday while driving I reckon that my mazda mpv 1999, diesel 4WD was overheating. Upon examining today I found out that the water-tank was exploding. what could have caused it?
ian saunders
Level 2:
New Friend:
  • Expert 133 Answers
  • Posted on Dec 30, 2013
ian saunders
Expert
Level 2:
New Friend:
Answers
133
Questions
0
Helped
32435
Points
290
Have you checked that the electric cooling fan is working ?? if so check the thirmostat by removing and placeing in boiling water and placeing a thirmomitor in the wather the stat should open at aprox 88- 92 deg, failing that have the head gasket checked
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jan 08, 2009
SOURCE: water pump replacement in a 2002 Mazda MPV
The reason is the water pump is driven off the timing belt, extra parts and allot more labor. No the eng does not have to be removed, labor time around 4 hours, parts about, about $125 US for parts, if it is a dealer add $75 US
Anonymous
  • 505 Answers
  • Posted on Feb 15, 2009
SOURCE: Mazda3 starter jammed
under the bonnet left down towards the ground
Anonymous
  • 9 Answers
  • Posted on Jul 27, 2009
SOURCE: 3 liter mazda mpv overheating
You probably never cleaned the cooling system out.
If you have not get it done by pros.
It seems something is blocking the flow. If the water pump went bad you will know. Rarely ever heard a impeller breaks off like you think. The bearings and the seal break first.
Check and see also if the heater valve is working.
As for the over heating even new thermostats fail. Reverse flush is needed or the procan measure the pressure in the radiator cooling system and edetermine if there is a engine pressure problem. Tools and experience is the key in the game of diagnosis.
wfg8.com
Anonymous
  • 27 Answers
  • Posted on Aug 05, 2009
SOURCE: engine overheating
All i can think of is the thermostat is not opening. or you may have a clog somewhere preventing the flow. Check the T-stat and hoses and radiator ( for clogs) Good luck
Anonymous
  • 15 Answers
  • Posted on Dec 02, 2009
SOURCE: mazda mpv overheating when driving
possible head gasket do a preasure test on the coolant system to see if it loses any coolant or presure drops and check for leaks hope this helps
I have a Mazda MPV 2003, i bought from japan, 7 months ago, this van was running well until two days ago, it stsrts and cut off, starts again and while driving it is losing power then it will speed up
Before any diagnostics, I would run a tank of gas with a bottle of fuel dryer and injector cleaner to ensure that the engine racing isn't resulting from moisture and clogged injectors.
Coolant leak
Only if you have to remove them to fix the leak. Make sure the leak isn't coming from the water pump, the reservoir, or from freeze plugs.
If it has overheated or is shooting water out of the tailpipe upon startup, you should have a mechanic do a pressure check.
2000 MAZDA MPV TURNS OVER BUT WONT START. RAN FINE YESTERDAY. GOT IT TO START TODAY AFTER HOLDING GAS PEDAL DOWN BUT NOW ITS PUTTING OUT.
Sounds like you possibly got bad gas, or your at the bottom level of your gas tank and got the nasty stuff. Try running a good fuel treatment through the system and fill it up with premium gasoline from Marathon
1helpful
2answers
I filled up my 2002 Mazda MPV yesterday at Walmart, Manning
Could be bad gas, water in the gas? Run the tank down to about 1/4 and put gas from somewhere else in it. Maybe higher octane for one tank full. Maybe put an additive in with it. If it clears up, then it was the gas.
2answers
3helpful
2answers
Mazda mpv overheating when driving
1helpful
How do i drain the fuel tank on 2001 mazda mpv
Why was this suggested? Did water get in it or another substance? If it's just been sitting in a safe place and it runs fine u should be ok. Go get some gas treatment and put it in there.
4 WD clunking and clicking sound when turning left or right
Sounds like the front drive axles are worn.My 89 MPV had the same "clicling" noise with an occasional clunk.The reason you feel it more in 4wd mode is because power is now being transfered thru the worn axles. I replaced both sides for approx $375(Axles rebuilt were 130 for drivers side and 110 for passenger side the rest was labor)
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
