How do I turn the receiver off on my Panasonic sa-bt330 so that I can use it with a separate receiver.
SOURCE: Panasonic SA-HE100 Remote
The correct replacement remote from Panasonic can be found in the link below.
Panasonic SA-HE100 Replacement Remote
SOURCE: Need 5 Digit Remote Code for a Panasonic Receiver HE-100
Try 1518 or 1039
/www.comcast.com/remotes/universal.html
SOURCE: F70 ERROR ON PANASONIC AV RECEIVER SA-HE200
This is essentially a protection mode indication. Either the output amp pac is defective or the regulator circuit is bad. Either option could be over $75 in parts plus labor at a local shop.
Let me know if you would like to attempt the repair and I'll try to get you more specific parts information.
Dan
SOURCE: Replacing a Surround Sound System Receiver
the difference is the "same speaker connections"
the front and rear will connect the same but the subwoofer is amplified by the HT75 , and the HE75 does not have an internal amp for the subwoofer speaker , only a "pre output"(has to be amplified)
