Tomtom ONE GPS Receiver Logo
Anonymous Posted on May 19, 2009
Resetting tomtom I pushed the reset button & lost all my information & settings. How do I retrieve this stuff? I have Tomtom one3rd edition.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
112
Points
I had to download from the start.
Thank you
daveydave47
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on May 21, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
3751
Points
23
My tom tom display is in a foreign language how do i fix this
Best to reset to factory settings and then reconfigure the unit as per instructions in the attached manual. All the maps and data will be lost and you will have to re-install. So make sure you have access to the map files which can be reloaded after the settings are complete.
Reset button is shown in diagram on page 2. Good luck. http://download.tomtom.com/open/manuals/one3rd/refman/TomTom-ONEv3-en-GB.pdf
1helpful
2answers
How do i update my Tomtom 3RD Edition (1GB) GPS Systems for free i would appreciate it if you have an answer thanks.
Hi, I was having trouble too and have found the manual for the 3rd edition online
I'm following these instructions:
Installing TomTom HOME
Install TomTom HOME on your computer in the following way.
  • Connect your computer to the Internet and then connect your TomTom ONE to your computer using the USB cable.
  • A pop-up window appears. Select Run TomTom HOME. Click OK and follow the on-screen instructions.
  • If the pop-up window does not appear, browse to the TomTom device on your computer and run the file named Install TomTom HOME.
  • TomTom HOME is also available for download from the TomTom website.
  • For more information visit www.tomtom.com/home
  • Once installed, TomTom HOME will start automatically whenever you connectyour TomTom to your computer.
Hope this helps, Lynsey
1helpful
Tom Tom 130 will not power-up ( no working screen) when power button is activated.
If your device is not starting up properly, follow the steps below:
soft reset:
How to soft-reset my navigation device Answer In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting.
To reset your TomTom device, do the following:
Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Reset your device.
Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.
2helpful
2answers
I need a manual download thanks michael
http://download.tomtom.com/open/manuals/one3rd/refman/TomTom-ONEv3-en-US.pdf
appears to be the right manual for your model
good luck
also see
http://download.tomtom.com/open/manuals/one3rd/onev3install.pdf
and also theirs
http://download.tomtom.com/open/manuals/RDS-TMCReceiverSupportGuide/RDS-TMCReceiverSupportGuide-EN.pdf
4helpful
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
  1. Check that the battery is charged properly.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
1helpful
Tomtomone3rdedition instructionmanuel
The Manuals can be downloaded here
http://download.tomtom.com/open/manuals/one3rd/manual.htm
if you look here
http://www.tomtom.com/support/support.php?ID=3&Language=1
(about halfway down the page) you can find more docs
Tomtomone3rdedition manuel
If you look about half way down this page
You can download all the manuals and docs.
This page gives you just the manual
8helpful
2answers
No Sound on my Tomtom one 3rd edition GPS
I did a hard reset (hit the reset button on the bottom with the power on) and the sound was restored when I powered it up. No settings or favorites were lost.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
