My proline android tablet fell and it wont turn on
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
SOURCE: Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
