Question about Tablets & eReaders
Proline L10A1G tablet. Call function problem
Hi guys. I have a Proline L10A1G tablet. We reset it to factory settings, and after that the function to make an receive calls was all gone. I cannot get it back. PLEASE CAN ANYONE ASSIST?? Thanks, Angie
Posted by Angie Mar on
AnswerMaster
    New Friend:
  • 17 Answers
Did you re download a program to use the call feature such as Skype? I don't believe your tablet has a call feature naturally on the device.
For the Android device there is the Google play store where you can search for an app that acts as a phone.
Please let me know if this helps any.
Posted on Apr 09, 2014
5 Related Answers
Curtis Richner
  • 461 Answers
SOURCE: setting up a laptop to use its tablet pc functions
XP Pro should run fine on it - I would assume that is what it came with. You may need to download additional drivers from Toshiba. I would check with Toshiba about the pen as well, but without it should still function as a regular laptop.
Posted on May 13, 2009
Anonymous
SOURCE: forgot my password pattern on
Forgot my password pattern how can I reset it back to factory for I will be able to use it
Posted on Dec 26, 2011
TechyDrood
Justin
  • 2072 Answers
SOURCE: want to reset to factory settings
This option will typically be under
Settings > Storage > Factory Reset
Posted on Nov 27, 2012
Deneenie
DLewis
  • 73 Answers
SOURCE: reset kurio 7 tablet to factory settings
press and hold VOL+ and Power button simultaneiously.
http://www.kurioworld.com/us/pdf/Kurio_Manual_US.pdf
Posted on Dec 22, 2012
elica_terry
Elica Terry
  • 6 Answers
SOURCE: my tablet is froze when i bought it it already had a password on it how can i fix it
HOW DO U REINSTALL OPERATING SYSTEM ON ANDROID 4.0?
Posted on Jan 06, 2013
1helpful
2answers
How to unlock a password for proline tablet H71930I
Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections. Use the volume buttons to move up and down through selection in this menu. Using the volume down button, scroll down to “Wipe data/factory reset”.
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Can't load fb on my tablet could this morning and now it wont
mine did this, i tried everything i thought. finally one of the geek squad guys told me to reboot my tablet. under settings you can reset everything back to factory settings. i uninstalled Facebook reinstalled it. but after i reset it back to factory setting it works like brand new. fast as ever. i lost all my data i had, so you may want to send it to another devise but this worked great for me. hope it helps.
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Why my tablet wont go to the home page
Do you mean it won't go to the "home screen" (past the android guy)? If yes then try to reset it (if a tiny hole on the back exists with "reset" marked, insert a tiny pin and push, so that it restores to factory default settings).
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
