SOURCE: Blanco dishwasher model BFDWC65 does
make sure the detergent box is clean and free from any sopa residue build up. if the box is clean then you may need to replace it.
SOURCE: I have a Blanco BFDWC65.
Hi
Check the water inlet water. Add water straight into the chamber manually as required, from the front. Close the door and run the machine. If air is trapped it will get cleared! Also check the free flow of water in the inlet rubber hose. Check the solenoid valve water inlet for functioning. If the solenoid valve is not opening, then the water flow problem can be occured.Also the float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Please get back to us if you have further query else please accept this "particular"suggestion. Thanks for contacting fixya.com
Before putting on the front panel:
