I can only get sound from my amp when I use the power amp out out put to my p.a.
SOURCE: marshall mg 100hdfx fan
Some of the Marshall equipment uses computer size fans and even on occasion the same connection.
Take the bad fan with you to a computer repair shop it will be much cheaper than a marshall part they should be able to help you out
Testimonial: "that sounds like the best way to do it..will just take fan to computer shop and try and get a replacement...thanks for the assistance"
SOURCE: I am having trouble removing head from Fender
I just removed the head from a rumble 100 I just got yesterday, you have to remove the 4 screws in the top, then the four that hold the handle on the top, and also the two from the sides. Slide the head out the back, but be careful of the wires attached so you don't rip them out (they are sort of short). Also be careful not to touch any electronic parts on the boards, some are extremely high voltage and can electrocute you (even when the amp has been unplugged)
SOURCE: Marshall Lead 100 Mosfet head, no sound.
For me when I couldn't get a sound a put a a regular cable or 1/4 Mono to 1/8 Adapter in the back where it says "Return" but not all the way about half way through. Make sure your cables are plugged in and are no high volumes while you do this because you want to be strumming as you pull in and out of the Return jack.
In case it isn't the Return Jack try it on the Output or Send.
One of these might be oxididate like my Return was.
