Ovens Logo
Posted on May 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Westinghouse Freestyle, fan forced oven Model NO 688.
The oven can only be turned off at the Wall breaker, ,and is therefore unsafe. I have had a sparky look at it and he recommends i get a new oven on/off switch. I am in Crib point in Victoria Australia, can anyone help with the type of switch i need , Please
  • megar05 May 15, 2009
    THe model is a Westinghouse "Free style" Fan Forced oven 688
Anonymous
Level 3:
President:
  • Master 1,865 Answers
  • Posted on May 15, 2009
Anonymous
Master
Level 3:
President:
Answers
1865
Questions
0
Helped
599494
Points
5720
I need a manufacturer name and model number
Westinghouse 688 wall oven. How can I replace the oven light?
GET A GOOD FLASHLIGHT AND LOOK IT OVER.
Aug 18, 2020 • Ovens
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 • Ovens
1helpful
2answers
Westinghouse oven 688 my oven wont turn off
Sounds like something has happened to your on/off switch that has caused contacts inside to stick in the on position. You will probably have to have it replaced.
Dec 04, 2013 • Ovens
3helpful
Hi there, I've got a westinghouse freestyle 521 glass stove top and fan forced oven. Just recently when in use the oven stopped working, although the light and fan remained on. Is there anything like a...
Sorry to read about your problem, I hope this helps you out.
sorry their is no simple fuse for what you are writing about, you may just have defective heat elements.or open thermal switches. and they are not easy to check
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 • Ovens
Oven not igniting and heating
Without the model number I can only give you basic information. If you are refering to the Glow Ignitor located in the center bottom rear of the oven concted to the burner tube, then this Ignitor could be bad and most tech's will change it first.
Even if it is glowing does not mean it is good.
For more detailed information please include as much information as postible and the Make and Model # off the machine.
Always unplug the machine when trying to service it.
Jan 10, 2010 • Ovens
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 • Ovens
44helpful
Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Apr 20, 2009 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
