Exeltech XP600 Sinewave Inverter 600W, 24V Logo
A
Anonymous Posted on Dec 16, 2013
Error code Oxf1 on new Epson printer - never used - what do I do?
Trying to print from iPad - getting error code Oxf1 on printer -- it is new and has never printed
Don A
Level 3:
  • Exeltech Master 4,499 Answers
  • Posted on Apr 03, 2024
Don A
Exeltech Master
Level 3:
Answers
4499
Questions
5
Helped
1337475
Points
25829
5answers
How Do I Resolve Epson Printer Error Code 0XF1?
You are getting late for a presentation and have given a print command to your printer. Your printing operation is in process and suddenly an Epson printer error code 0xf1 appears. Pretty frustrating, right? If you are in mayhem and looking for methods to fix the printer 0xf1 error code, you are at the right place.
The major issue with this Epson printer error code is that it hinders all the ongoing printing. This glitch prevents the printer head to move right or left, and hence mars the functions. The problem could be due to some hardware or software blunder. Irrespective of the root of this problem code, this article provides a comprehensive answer to how to repair error code 0XF1 on an Epson printer; and the best part is you needn't be an expert to do it and could implement it it it with ease.
What causes Error code 0xf1 issue in Epson Printer
The Epson printer 0xf1 error problem can stem due to numerous causes. The reasons could be:
  • The registry entries are corrupt.
  • The drivers are obsolete.
  • The system is infected with malware or virus.
  • There is a stuck piece of paper in the printer.
Fixing Epson printer error 0XF1 There are 3 easy solutions to resolve this problem. You could try any of the methods to resolve the issue.
  1. Turn off your Epson printer and remove its power cord. Turn it on again. At times, restarting the printer resolves the issue. To add, also conduct an antivirus scan to remove any viruses.
  2. Uncouple the ink cartridges and affix them. Also, inspect for any paper jams.
  3. Switch off the printer and remove its power cords. Wait for 10-15 minutes. Once the time elapses, attach all the cords and turn on the printer.
Also Read: Epson connect printer setup utility
2helpful
9answers
How do i epson error code 0x9e?
The printer is bad. Epson printers are known for the 0x9e code. It would cost more to repair than to just get a new printer.
Getting error code OXF1 on Epson WF 3640
Epson Workforce WF 3640 error code 0xf1
It published a solution for the 0xf1 error code. They claim that this error can occur because of a corrupted registry entry in your PC. They say that the print head will be unable to go or read from left or the right side while it is performing the printing process
Steps To Fix Epson Printer Error Code 0xf1. This technical issue might due to software or hardware problems with your printer or computer. The main step that you can perform is to unplug the printer from the main socket, remove the printercartridge, and then reattach it.
Epson 420 printer has error OxF1....how do you fix it
Here is one web reference that may help.
If you are lucky the issue has to only do with the printer and unplugging it/removing cartridge/reinstall may fix the problem. If that does not work then supposedly the problem is created by your PC and that is much more a pain to fix
http://printers.iyogi.com/help-support/errors/fix-0xf1-epson-error-code.html
Good luck on your troubleshooting
What is error OxF1
0xF1 means there is a paper jam. Are any of the lights on the machine flashing? Are any of them solid ? Epson WorkForce WF 3520 All in One Printer
Error code OxF1
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Top Exeltech Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Exeltech Electronics - Other Expert? Answer questions, earn points and help others
