2000 Chevrolet S-10 Logo
Jacqueline Burton Posted on Dec 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turns over but wont start
Started ran 10 minutes to warm up then it just cut off now wont start, it turns over but that's it
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Chevrolet Master 1,449 Answers
  • Posted on Dec 15, 2013
Daniel Mc Entee
Chevrolet Master
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
276036
Points
3556
Is this diesel or petrol.if diesel then look to your fuel pump.under it is a plug .remove this and drain what will be water on the bottom of it.only a small amount then refit.now pump the fuel up to it is very hard .then get someone to turn the engine over .as you keep pumping should then start.that is done due to air in the system. if petrol you need a spark plug tester.check the coil has a spark .then check the leads at the spark plugs are getting a spark .then check the plugs for a spark .smell them .do you smell fuel on them .if so change the plugs.
Testimonial: "son went and checked it, it starts if you spray carb cleaner in but cuts off as soon as you stop spraying. sounds like fuel pump is running so replaced fuel filter. still wont start. ( it is getting spark)"
5 Related Answers
Anonymous
  • 33 Answers
  • Posted on Jan 10, 2009
SOURCE: car will turn over but wont fire/start.
could be a problem with the MAP sensor. I have a 93 escort and it had a simalar prob and it was just a dirty map sensor. I cleaned it and it is running exelent now.
Anonymous
  • 67 Answers
  • Posted on Apr 06, 2009
SOURCE: , will not start, no pressure in tank,
If the pump runs check the fuel pressure it could also be the fuel pressure regulator
Anonymous
  • 1129 Answers
  • Posted on Oct 02, 2009
SOURCE: I started my car this morning, let it run for
The car should be storing a trouble code bring the car to an Auto zone auto parts store they will run a free code check this will point you in the right direction, I don't like to speculate this results in uneccessary cost to you, if I had to guess it would be a crankshaft sensor is bad or ignition related.
Testimonial: "Thanks for the information. I willCheck it out."
Anonymous
  • 10 Answers
  • Posted on Dec 20, 2010
SOURCE: tried to start the truck---nothing
sounds like a bad connection,it wont heat up the solenoid or the starter,check your hot and negative cables from battery to starter first could be the starter itself, ggod luck
Anonymous
  • 752 Answers
  • Posted on Apr 21, 2011
SOURCE: Changed oil and filter, started vehicle, ran good
Talk to your auto dealer for the car or to Chevy . com.
Could bad maf sensor and bad idle air valve have vehicle stall then hard to start for awhile and cuts off after 10 minutes of driving
I would also suspect the ignition module. They tend to work ok for a few minutes when they are cold, then fail once they warm up. If you wait awhile for the ICM to cool down, it will work as well as it can until it warms up again. A code scanner is your best friend to know where to start looking, and to perform tests and log data.
Car cranks won't start
I'd change the plugs as per this link, and swear by an 'internal service' by chemicals as manufactureed by BG Products available on Ebay (The chemicals are for professional use so stick to the instructions). If you haven't seen this thread, take a look.
https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/xj8-starting-problems-62830/
I
2answers
Turns over wont start
It sounds like there is no pressure in the fuel rail. The cause is the fuel pump is not working. I had one like that and the pump was running but not pumping. Check to see if the FP is putting out.
Good luck.
I have a 1993 chevy k3500 4x4 6.5L turbo desiel. it sat for a long time bfore i puchased it. previous owner drove it 30 km to my location. bought it. replaced exhaust, starter( bad previous starter would...
can check these codes (if any) by jumping the A and B terminals at the diagnostic port under dash with key in on position engine light will flash and have to count flashes also sounds like it may have an air bound fuel system
My 2004 ford explorer will not start it ran for 30 minutes warming up and then cut off and then it would not turn over to start
tMy 2004 Ford Explorer ran today for about 100 miles I turned it off and it wouldn,t start. It turns over and almost starts. We had the air conditioner on during the 100 miles.
1helpful
When i start the truck up it will not idle
Is the engine at running temperature when it starts running rough? And when it is cool does it run fine until it warms up?
Truck wont restart when it's ran for greater than 5 min.
Will it restart warm if you hold the accelerator to the floor?
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
