SOURCE: Automatic Gear Shifter Light Burned Out
You shifter indicator bulb (194 bulb number) has burned out. Pretty easy and cheap fix. The top of the indicator has to be removed/lifted up and teh bulb needs to be replaced.
SOURCE: 04 Navigator gear shift button broken
I only have 2003 Nav procedure. Maybe get used part at car-part.com. Page with * is lowest price.
SECTION 307-05: Automatic Transaxle/Transmission External Controls
2003 Expedition/Navigator Workshop Manual
REMOVAL AND INSTALLATION
Selector Lever —Floor Shift
Removal and Installation
SOURCE: Gear shifter sticking (auto) from Park to reverse and vice versa.
you need to have the shifting cable lubricated or replaced.
SOURCE: automatic transmission doesn't shift into gear right away, there is a long lag before it engages
Hello There
Sounds like your transmission oil needs to be changed, when was it last changed?
Hope this helps, please don't forget to rate me.
SOURCE: automatic transmission wont catch into any gear
You sould have been moore frequent on your transmission fluid changes, and you shouldn't have taken it to Jiffy Lube either. Your best bet is to drain and fill the trans fluid run it shift gears. Drain and fill again. Do this 3 times. Yeah the transmission fluid is expensive. on the last drain and fill you want to get a bottle of LUBE GUARD from NAPA or who ever sells it. put the whole 10oz bottle in. Shift Rev, 1, 2, 3, D. Neutral Rev D. If that don't work then you have bad seals.
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
1996 Toyota Corolla: Transmission
Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
Gear
indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high
gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will
Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while
driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
Transmission not engaging in first
gear?
Vehicle only goes
in First gear?
Engine will not go out of park mode?
Car stuck in park?
Car will not come
out of Park?
Automatic
transmission will not go into high gear?
Car wont downshift
sometimes?
Transmission
will shift into drive?
Auto wont shift
from park?
Car Transmission
Shift indicator
directly goes to 2nd when key is turned ON?
Third gear missing
Vehicle has whining sound in gear?
transmission?
hard to move on cold mornings?
Gear shifts hard?
delayed shifts while driving?
This will help.
Thanks.
FOR
MORE HELP GO TO: ---
Car repair guide?
http://technoanswers.blogspot.in/2012/03/car-repair-guide.html
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
