Insignia - Flex 10.1" Tablet with 16GB Memory Logo
Skyler Gilbert Posted on Dec 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Insignia tablet won't turn on
My Insignia flex 10.1" tablet has been charging all night and now it won't turn on
Justin
Level 3:
  • Insignia Master 2,072 Answers
  • Posted on Dec 08, 2013
Justin
Insignia Master
Level 3:
Answers
2072
Questions
0
Helped
432125
Points
5629
Probably defective tablet. Here is some good advice, return it or throw it away and spend the $200 on a google nexus 7. Insignia is one of the worst electronics manufacturers in existence. No joke.
I got a insignia tablet flex 8 that has windows that is locked.
PDF]USER GUIDE Insignia Flex™ Android Tablet
www.insigniaproducts.com/.../NS-14T002_13-0622_WEB_V1_ENG_Fi...
Oct 11, 2013 - 8. NS-14T002 Insignia Flex™ Android Tabletwww.insigniaproducts.com. Setting up your .... Unlocking and relocking your tablet. When you turn ...
NS-13T001 Insignia Flex™ Android Tablet
www.insigniaproducts.com/cms/documents/manuals/tablets/.../help.html
Creating a screen unlock pattern ... Your Insignia Flex Tablet represents the state of the art in Android tablet ... Your tablet's internal storage capacity is 8 GB.
Insignia (Bestbuy) Flex 10.1 Tablet unlock - XDA Developers
forum.xda-developers.com > General discussion > Questions and Answers
Jan 17, 2014 - 3 posts - ‎3 authors
Insignia (Bestbuy) Flex 10.1 Tablet unlock Questions and Answers. ... UnlockBootloader, Install TWRP and Root the Huawei Mate 8 ... the tablets bootloader isUNLOCKED already, I tried the OEM unlock command in adb and ...
Creating A Screen Unlock Pattern - Insignia NS-14T004 ...
www.manualslib.com > ... > Tablet > NS-14T004 > User manual
You can increase the security of your tablet by creating a screen unlock ... 101. NS-14T004 Insignia Flex™ Android Tablet ... Wi-fi windows 8" tablet (86 pages).
I have an Insignia Flex 10.1" tablet with Android model NS-14TOO4 and it boots up to the insignia screen and stops will not load, how do I reset my tablet?
Some tablets reboot by holding the start button for about 10 seconds and releasing. Wait another 10 and try turning on as normal. Maybe yours is one of them.
Does insignia 10 inch tablet use sim card
Of all the Insignia tablets, there is only one that will use a SIM card. It is specifically called out in the model number as an LTE capable unit.
The model numbers are the NS-15T7LTE and the NS-15T8LTE.
No other INSIGNIA tablet will have a SIM card slot available.
2answers
Why wont my tablet lock and the volume keys won't work?
in settings, try to put the "sleep" timer to 2 minutes, and see if it actually locks (or sleeps:turn off the screen)... also with mine sometimes the "capture screeen" feature works (more donts than do's!) perhaps very poor quality from the buttons.
clean all the apps running, and start with a full fresh boot (turn off by holding the power button 10 secs or more, then conecting to the charging usb, press again the power button), the volume also can be set via software, again in settings.
2answers
Tablet won"t charge with charger
Make sure you are using the charger that came with the unit.
Wiggle the cable in the USB port on the tablet to make sure you have a connection and that it isn't a faulty USB cable or that the USB port is failing.
Try using a different charger that will deliver 5 Volts at 2 Amps...no less.
If none of these solutions work, return the unit to the GeekSquad Bench and have them look at it.
Insignia flex tablet will not turn on
Make sure the battery is fully charged and left plugged in while you try to turn on the tablet.
Hold down the power button (it takes a long press) until you see the INSIGNIA logo on the screen.
If it takes longer than 10 seconds and the unit hasn't turned on, the unit is not functioning properly.
If you have the protection plan, I would recomend you return it to Best Buy for a new one.
Top Insignia Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Insignia Tablet and eReader Expert? Answer questions, earn points and help others
