My notebook contains an optiarc dvd rw ad-7585. The dvd opens immediately after turning it on and won't close. If I try to close it, I can hear the normal closing sound and directly a kind of release click and it opens again. Is there a way to fix it, or is the player beyond repair?
SOURCE: Optiarc DVD RW AD-7561A This device cannot start. (Code 10)
I beleive that this code is being displayed under the Device Status in the Properties window of the DVD Drive in Device Manager.
If it is so, you need to do some modifications with the Registry to resolve the issue and I am sure that the issue will be resolved with this.
However, since you had not specified the Operating System which is installed in the Notebook is Vista or XP.
However, I am providing the links which includes the steps for both Vista and XP to edit the registry to resolve the issue with Error Code 10 with the DVD Drive in your Notebook.
Removing Upper and Lower Filter in XP :
http://support.microsoft.com/kb/314060
You need to perform the steps listed under Advanced Troubleshooting to delete the Upper and Lower filters.
Removing Upper and Lower Filter in Vista :
http://support.microsoft.com/kb/929461/en-us
You need to perform the steps listed under Resolution in the link above.
You may not find both the Upper and Lower filters according to the instructions links provided above.
Delete the ones among the Upper filter or Lower filter or both which you find in the locations mentioned.
This should solve the issue...
SOURCE: having problems with my optiarc dvd rw ad-7580S
clean the dvd rw wihth lense clenaer or window cleaner put a few tinhy drops on the disk put in and when dik is dry its done, also unplugg and plugf bk in all connections esspecially ur dvd rw
Testimonial: "Thanks guy! I appreciate the assist!"
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You
may also want to open Device Manager and verify that the yellow exclamation and
error code on the CD or DVD drive is gone.
hope this helps
