Hi Yeska
No the Quinny Zapp / Quinny Zapp Xtra chassis is not suitable to use with a carrycot. Due to the lightweight and short wheel based nature of the Zapp / Zapp Xtra chassis design the use of a carrycot is dangerous as it may cause instability / tipping.
The Quinny Zapp / Quinny Zapp Xtra chassis can be used with a Maxi Cosi Pebble or Maxi Cosi CabrioFix carseat but not a carrycot.
SOURCE: Please can you tell me
This site has most of the Quinny manuals
www.karlisles.com.au/baby_repairs_spares/instruction_booklets
SOURCE: Hello, I have a quinny zapp stroller model: EN
This would be a good starting point:
www.quinny.com/ot-en/strollers/quick-use/accessories
Hope this helps.
SOURCE: Adapters for quinny zapp xtra have been lost on
Good Afternoon
Replacement recline adaptors can be ordered via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 25GBP and if ordered direct there will be 3.99GBP p+p charge.
SOURCE: how do i attatch the quinny zapp xtra seat to the quinny zapp frame
Yes the new seat unit can be used with old zap.You remove the fabric seat (look on u-tube if you don't know how)the new seat unit then fits on to frame via the addapters that come with the xtra seat unit, at the point where the car seat addapters fit.There is a large push button on the top of the seat unit which you push in to recline or sit up the seat, and a little one too next to it, that needs to be pushed away from the larger one, while you hold the large button down when you want to remove the seat unit.I found fitting the xtra seat very easy.To fold the zapp you Must remove the entire seat unit as it won't fold with it on, unlike the old one.
