Straight Talk LG840G Cell Phone Logo
A
Anonymous Posted on Nov 27, 2013
How do I find my pin number - Straight Talk LG840G Cell Phone
Asking for pin number we don't know the pin number
Most of the time the pin is on a card delivered with the device. Or in the manual you can fine a generic pin to start. With a generic pin (often 0000) you are advised to change the pin during setup.
tip
How to find the PIN code of Cell Phone
Hello <br /> Personal identification number (PIN), is a secret number that is used to unlock the phone, unlock in the sence of accessing the device you are using. It is made up og 4 digits that is giving to you when you buy a phone number. It comes with your phone number not with the device, so that means you can still use the same pin on different mobiles. But always remeber your pin number because if you lose it then your phone will be probably blocked! <br /> Following are the some ways to find the pin code: <br /> Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones. <br /> Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN. <br /> Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number under the battery. Reinsert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen. The last four digits on your IMEI number can occasionally be the service provider's preset PIN for the cell phone. <br /> Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and NIC number. <br /> Hope this helps, if so do rate the Tip.......
on Feb 01, 2011 • Cell Phones
Vizio VZ42L. HDTV has stereo speakers connected by what appears to be 5 pin DINS to the television. I would like to use one of the two speakers as my "center" speaker for the surround sound. Is...
Hello
Your Vizio has a 5 pin din connector to take the speaker connection out. There is a 'noch' in the din socket from which count towards left; the first is pin number [1] second is pin number [4]; third is pin number [3]; fourth is pin number [5]; and fifth is pin number [2]. Out of these, pin numbers [2.4&5] has no connections from inside, that is [NC]; not connected. Pin numberes 1&3 are two speaker positve terminals, and the body of the 5pin din pin will act as negative to both channels, that is common.
The company has provided only two channel stereo sound from it to out. There is no provision to get a center speaker out of it. OK.
2helpful
Forgot mxit pin & dont recieve a sms cuz my mxit number is not my cell number ,so wat do i do
Dear Friend, To get your MXit Pin Number SMS ‘pin’ to 34006 from the cell/mobile number you initially registered when you register for the MXit service. Once you’ve sent the sms with the message ‘pin’ to 34006 you will receive a reply with your MXit pin number.
I think there is no other way to get your MXit pin number at the moment.
Hope This HElped YOU.......
Thanks for Using FixYa
3helpful
2answers
Pin number
pin number is never put on the unit. if u need a pin number its in the users manual/set up manual if u never changed the origanl pin upon setup. on the back of the router there should be a reset button pn sized of course which will set it back to manufacturers settings which will then take the origanl manufacturers pin number which is in the setup manual
I don't know the pin number to my bluetooth HBM-730
Are you trying to pair these two devices? In that case enter any number as your PIN when prompted and enter the exact number in the other device when it asks for. PIN number is asked when you try to pair two or more bluetooth devices. PIN can be any number but make sure you enter the same number in all devices.
I hope it helped.
Feb 10, 2009 • Cell Phones
11helpful
5helpful
How do I find the PIN number for my linksys WRT54G2 router
I have had this problem. Go to the website and get the free phone number and ring them. They were able to help me (twice as I forgot after the first time).
Where do I find my PIN number ???????
PIN number stands for Personal Identification Number
Most Credit Cards have PIN number.
If you are being asked for a PIN number by a program running on your computer
you can consider that program to be dubious or hacked.
Most software vendors employ a PRODUCT KEY , not a PIN number
PIN numbers are for financial transactions.
If you are being asked your PIN number by a program other than your BANK
or a site that you are purchasing software from , then you are most likely being
tricked by an evil hacker and should not proceed to give them any PIN number.
If this is your credit card or bank card or debet card you are talking about.
Your pin number will be located on the back of the card , the last 3 digits.
Thank you for using FixYa!
Az.
Top Straight Talk Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Straight Talk Cell Phone Expert? Answer questions, earn points and help others
