AMD FirePro V4900 Graphic Card - 1 GB GDDR5 SDR PCI Express 2.1 x Logo
User manual amd firepro V4900 dual 1 GB
Looking for user manual and how to set up dual monitors
1helpful
Is AMD FirePro M5950 as strong a Graphics card as My Elitebook 8560w can get?
hp parts surfer, go there, tell country
and product number for PC
(I have this PC)
and what you see there is all you get.
its all there, read it.
https://partsurfer.hp.com/partsurfer?searchtext=8560w
first clue there is this
Heat sink with fan - For use in models with AMD FirePro M5950 and NVIDIA Quadro 1000M graphics cards
Samsung Syncmaster 305t Not displaying full resolution with Dual Link DVI cable.
2560 x 1600 at 60 Hz support . if may v sync 75Hz need to check the adjust.
Manual needed
go to amd/ati.com Amd bought ati I believe you can still get manuals in pdf form from them free
Amd firepro v4900
You must have enough power to supply your graphic card. Buy a better power supply atleast 750w+.
Check your VGA or DVI or HDMI cable.
Make sure your graphic properly plugged in.
Red blue and green patterning on the monitor
You can try switching out the VGA cable (the one with the blue connectors on each end). If this does not work, try a factory reset on your monitor.
Hello, How can I setup my 4 monitors using a FirePro V7900? I have it on a Dell precision T7500. All the monitors are connected and detected by the graphic card Right now is working with only 2 monitors...
Hi, If u see on the bottom right corner of the task bar their is a red icon for ATI Catalyst Control Centre.Open it and on the top left corner of that their is a drop down menu, In that menu select Desktop and Displays.in that you will see all four monitors if not then theirs a button for detect displays, when u click on that button all four monitors will start showing on the window in the console.now u can set any one of them as primary monitor and respectively others as secondary and so on..Then click ok and thats it..
2answers
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenomâ„¢ FX / Phenom / Athlonâ„¢ / Sempronâ„¢
AMD Cool 'n' Quietâ„¢ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenomâ„¢ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
3answers
Brand new motherboard wont start up
try taking 1 stick of ram off the motherboard, and boot up with 1 stick in slot 1 or 2.
You should get some beeps, 1 is system Ok.
3 is usually RAM/Graphics problems.
Also try booting with the motherboard setup disk in the CD Drive, it may be looking for files to initialise the Board.
And the obvious, check that all cabling is correct from mainboard to front panel. Power on/off Reset et,c.
View the user manual to see if the board has any jumper/dip switch settings for different configurations.
Mike @ compurepair.
Top AMD Computers & Internet Experts
ExpressFiX
ExpressFiX
NOEL
NOEL
john h
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
