SOURCE: Digiscope
Hey timpo,
I would definitely use some kind of remote release since even the smallest amount of camera shake (pressing the shutter button) can cause blurry images in high magnification images. At the type of magnifications usually involved in digiscopeing the depth of field of your images will be greatly reduced and you will need to set the camera to a smaller aperture than usual, which should result in slower shutter speeds. I would definitely have the camera set to manual exposure mode so you can control both the shutter and the aperture although aperture priority should also work well. I would not set the camera to a higher iso since you will lose quality, and since I am assuming you are using a tripod slow shutter speeds should not be an issue. Any movement by the subject will blur the subject if you are using slow shutter speeds so if this becomes an issue you can set the camera to a wider aperture at the loss of depth of field to achieve a faster shutter speed. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
