I have a 98 f-150 that the rear seal on the drive shaft is leaking. Do I need to pull apart the diff to replace the seal or can I remove the yoke and replace the seal.
Yes, but you will need to mark the yoke position and exact number of turns to remove the nut or you will change ring and pinion gear lash setting when re-installing it. You can use a large pipe wrench to hold the yoke still while tightening, or get a special tool made for that.
Remove the drive shaft and the nut on the yoke, you do not need to remove the diff cover at all. Get a new seal and nut, because they are a lock style nut usually. Good luck!
Is there a torque value I need to get to or is the rotational count all I need?
