The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Connect the usb cable between the camera and the computer. Make sure the camer is off. After you connect the camera to the computer, then you can turn on the cameral. Go to My computer and you will see all the drives. Look for VTech 773. Double click on the drive and you will see a PHOTO folder, pictures will be there. Remember: if your using an SD card, then you will see that under removable drives. Your pictures could be there too.
Hi, Please try this, turn on your camera, insert a blank memory stick, slide the side switch down to the lowest point, should say “No file in this folder” click on menu, click on Setup, use the arrows and go to Memory Stick, choose “Copy” choose “Album” the “OK” this will copy all you pictures from the Album in your camera to your memory stick.
You need to go to MENU, roll down to SET UP
if you roll down you would see at top
"Camera1", "Camera2" and "Memory Stick"
go to Memory Stick and roll down to COPY
go to ALBUM...
and then she ask you...All data in Album will be copied. Ready? touch OK ....
Now you create a folder with all the photos in the memory and you can download it.
I hope this help you...Liz Annette PR
To transfer pictures:
1. Remove the memory card from the camera.
2. Insert the memory card into the floppy disk adapter.
Make sure that you insert the memory card into the adapter with the gold side of the memory card facing you and to the right and the silver side of the adapter facing away from you.
3. Insert the floppy disk adapter into the diskette drive on your computer.
4. Double-click the PhotoMAX shortcut on your desktop to open the software.
5. Click Get Photo.
6. Click Album or FlashPath.
7. Click Downlod from FlashPath. The images appear as thumbnails on the album manager window.
8. Double-click the image that you want to edit. The image appears in the image tray.
9. Remove the FlashPath Floppy Disk Adapter from the diskette drive when you are done.
The IR-500 allows you to create custom photo albums that can be organized in 12 separate albums for easy viewing. Each album can hold up to 100 images. As a result, users can carry their favorite photos right in the camera, and enjoy viewing them wherever and whenever they wish.
