I have a rumbling noise from the clutch - pull the clutch lever in even the smallest amount and the noise goes completely and it sounds great again.
Can anyone tell me what is causing the noise and what needs renewing to sort it.
Thanks
The clutch has two different types of needle bearings. One flat thrust bearing about 1" diameter and one caged needle bearing. The most likely culprit is the thrust bearing. This is a 5 to 10 dollar bearing and easy to replace if you have an impact driver to loosen the right case cover screws. Drain the oil, remove the right case cover then the clutch end plate. The bearing is there, and will probably come off with the plate.
SKU: 09263-10002 THRUST BEARING
