The vent is fine. I tried jumping out the thermal fuse and thermostat. They both seem good (zero ohms at room temp). It will light sometimes then goes off. After a while the glow coil will glow then go out leading me to think it is the solenoid for teh gas valve. Does this sound right?The vent is fine. I tried jumping out the thermal fuse and thermostat. They both seem good (zero ohms at room temp). It will light sometimes then goes off. After a while the glow coil will glow then go out leading me to think it is the solenoid for teh gas valve. Does this sound right?
You can't post conmments that contain an email address.
Try disconnecting the vent hose - if this corrects the problem then you vent was either kinked or plugged up and will need cleaned out. A leaf blower is the easiest way to clean out the wall vent.
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
If you find that the dryer initially lights, then goes out and the igniter coil glows, then also goes out, it's the valve solenoid coil, about $25.
There is a temperature limit switch as well. This usually either fails entirely (no heat at all) or operates the burner out of the normal range (often showing up as clothes taking too long to dry).
A clogged dryer vent will cause problems with heat cycling, too.
first check to make sure the venting isn't blocked by lint. second, check the igniter, if it is orange in color you need to replace it, it should glow white.
Watch the
igniter. Does it glow bright orange, then shut off without igniting the
gas? (When the gas ignites there's a large blue flame.) If so, there
may be defective coils on the gas valve. Mounted on the top of modern
gas valves, there are black electrical coils. The coils, when
energized, open the gas valve. If one or more of the coils are
defective, the valve doesn't open and the gas cannot ignite. Because
it's often difficult to properly test the coils, it's usually best to
replace both (all) of them at the same time.
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
