GoVideo DVR4000 DVD Player/VCR Logo
G
George Kiesel Posted on Nov 11, 2013
Blinking red light on panel keeps ejecting tape
Madi Misaki
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 58 Answers
  • Posted on Nov 12, 2013
Madi Misaki
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
58
Questions
0
Helped
7107
Points
65
There seems to be problem with the ejecting mechanism of your device. It is not properly closing. Try opening the device and clean the ejecting mechanism and load tray. If the problem persists, get repaired at the authorized service center.
Blinking red light won't record
Hi, You might have a tape in the VCR that has the 'record tab' broken-out, prohibiting recording. IF you want to record, eject the tape and put a piece of scotch tape over the missing square tab on the bottom corner of the VHS tape. Good luck and let me know if that works for you.
My Sony TC WR 535 wont open doors, one cassette in deck B,lights blinked in display panel then unit shut down, not been able to turn it on since
Remove the cover after unplugging AC. Look for a plastic stop that keeps the eject button from going in farther. Move the plastic stop peice downward and the buttom will then move in all the way and tape will eject. On mine the plastic piece is white and rotates down.
Where light is for controller port four its flashind red and xbox will noy work?
hi, this is what that code is telling you, also do you have a code on the screen when switched on let me know if you do if you dont ill tell you at the end of this post how to get an error code so i can tell you exactly what the problems is.
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
here is how to get the secondary code for me.
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 1 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code ( so 1 red light may be lit so write this down).
* Release the eject button and press it again.( it will then change the red lights and maybe 2 will be lit up write this down also)
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 1 red flashing lights.
so what you need to do is this, when the 1 red light comes on hold down the little white sync button and keep holding it down all the time, now whilst your holding that little white button down on the front of xbox press the eject button but keep holding the white button down now write how many lights are lit up and this is the 1st number in the code, so keep holding the white button down dont let go of this white button then press and let go of the eject button again and write how many lights are lit up whilst still holding the white button down, now do this 4 times all together and you will end up with something like this written down
4402
once you have this four digit code send me a message back with the code then i can tell you exactly what the problem is and what you can do to try and solve the problem
let me know how you get on or if you need further assistance ok
The game cd cannot be ejected from the PS3. When the eject button is pressed the red light keeps blinking.
Try the following solution.
Turn the PS3 off with the main switch on the back.
Turn the PS3 back on into standby (red light on)
While holding the eject button press the power button on the front of the PS3. This should initialize a forced disc eject.
Hope this helps and thank you for using FixYa
1helpful
The red light keeps blinking and won't eject disc
You have the dreadful blinking red light of death. Long story short the system is broken and you have a few options:
  1. send the system to sony and receive a refurbished system for $150.
  2. find a local to do it for much cheaper
  3. watch vids on the web (youtube.com) and fix it yourself but it is fairly difficult.
  4. buy a new ps3.
I hope I have helped and feel free to ask me any questions and let me know how it goes.
1helpful
One flashing red light on xbox360 ( not red ring)
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
The LEDs will now blink the first number in the code (as described below).
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Red light blinking, when on Standby
If you have a warrenty take it back. but thats the sound itmakes when you try to eject the disk and nothing is in there.
4helpful
Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
2answers
1helpful
Camcorder is not recording
the capstan motor of the camera is not running that why the power display is blinking and when you eject the tape there a portion of the ribbon that left..it is a poor connection of the capstan motor to the main board of the camera....
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
