Kitchen Appliances - Others Logo
c
caitlin4377 Posted on Nov 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reading eggs login
Wont let me sine in
Vitally Alcher
Level 3:
  • Master 1,645 Answers
  • Posted on Dec 29, 2013
Vitally Alcher
Master
Level 3:
Answers
1645
Questions
Helped
467406
Points
3209
LITTLE RED LOCK SINE ON DRYER DRYER WONT START
That is a lock sign that means the keypad is on child lock mode.
Feb 01, 2016 • Dryers
How do I log into reading egg for kids
You may have to start a account and then login, usually free.
My TI-30XB WONT CALCULATE INVERSE COS OR INVERSE SIN
Does it refuse to do so or does it give an error message?
Three common errors:
  1. Not having the correct angle unit. Wrong result, No error message
  2. Confusing reciprocal of sine (1/sin(x) with arc sine (x) ,sin^-1(x). Confusing the reciprocal of cosine, 1/cos(x) with arc cosine (cos^-1(x)). Wrong result, No error message
  3. Taking the argument of the inverse sine and/or inverse cosine functions outside the interval [-1,1]. This gives a domain error.
Abc reading eggs login
Contact the software's Support.
I cannot access egg buddies nor can i send gifts or buy chips
See directions on egg buddies web site.to remove egg buddies and add it back. (FIXYA is a service to answer questions and is not connected to Facebook or Egg Buddies.)
I cannot login to Egg buddies with facebook Certain users are having problems accessing Egg Buddies using their facebook account. This is usually caused by some malfunction on facebook's side. It might help if you try Removing Egg buddies and then try to login again (You will be asked to add it back). To remove Egg Buddies, click here and click on "Remove app" (left column, bottom). Don't worry, you will not lose any of your egg buddies statistics and trophies by removing it. Then click again on "Go to app" to re-install egg buddies.
Egg Buddies - go to this link and click on Help
3helpful
Why does my dr3624 only put out 98 vac, its rated at 120 vac? i'm off grid and my batteries are new 24 volt
Are you using a true-RMS voltmeter to measure the DR's output? The DR's output is modified sine wave, and a cheap average reading AC voltmeter will give you a reading of 90 volts or so. Alternately, if you have an oscilloscope, you can verify that the modified sine wave is around 170V peak to peak. It should alternate in segments of -170, 0, +170, 0... The duty cycle and peak voltages will vary with the inverter load.
- Tom, Sun Electronics International, Miami, FL
1helpful
Hi i have a 400w black and decker inverter as soon as i plug my lap top in to it the power light on the inverter flashs and it wont power my laptop
The output of this inverter (and most others) is a modified sine wave, which isn't quite the same as a true sine wave - like you get from a wall outlet. Unfortunately, most transformers (which is essentially what your laptop power-supply is) require a true sine-wave. Your inverter will work fine for many other 110V applications. You can buy an inverter with a true sine-wave output, but they are more expensive.
1helpful
2answers
I got a output voltage of 100.1 on a trace dr3624
The rms voltage is what counts, because it tells how much power the output will deliver to a resistive load. Inexpensive multimeters on their AC ranges are usually average-responding rms-calibrated meters. This means they measure the average of the absolute value of the AC component of the signal, and display that average multiplied by about 1.11 (actually, pi over sqrt(8)), the ratio of rms to average value for a pure sine wave. That way, the meter will give the right rms reading for a sine wave.
If the signal is a square wave, where the average and rms values are equal, the average-responding meter will read 11% too high.
Many inverters put out a modified sine wave (MSW), which sits at zero for a while, goes to a constant positive level for a while, goes back to zero for a while, and goes to a constant negative level for a while to complete the cycle. The positive and negative parts of the signal have the same magnitude and duration.
The rms and average values of an MSW depend on its duty cycle D, the fraction of a cycle for which the signal is not at zero. In a well-designed inverter, the duty cycle will be adjusted when the DC input voltage goes up and down to maintain the nominal rms output voltage. If we use peak voltage Vp to mean the magnitude of the positive and negative voltages the signal goes to, then Vavg for an MSW is equal to Vp times D, and Vrms is equal to Vp times the square root of D.
The duty cycle for which an MSW will have the same rms to average ratio as a sine wave is 8 over pi squared, or 81%. For any duty cycle less than this, an average-responding meter will read a lower voltage than the inverter rms output, and for a duty cycle higher than this, the meter will read too high.
If your MSW inverter is putting out 120 volts rms and its duty cycle varies from 50% to 75%, the meter reading will vary from 94 volts to 115 volts. I avoid the problem by using a Radio Shack 22-174B true rms digital multimeter.
No server
I can sine in but wont load mesages
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
