20 Most Recent Xantrex Technology DR2412 Inverter / Charger Questions & Answers
Inverter output voltage (eg. 96 volts) not if this is an issue
96 volts is low. 106 volts is low. You need to be about 110 to 120 volts optimum. How is your battery input? This is crucial for the inverter to output correctly. If it needs 24 volts DC in Then make sure it's 24 volts. 48 volts means 48 volts. Check the battery voltage and compare to inverter input requirements first. If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
7/5/2016 1:57:55 AM • Xantrex... • Answered on Jul 05, 2016
0answers
Pc02017-26e-y
Be the first to answer 3/1/2013 3:02:20 AM • Xantrex... • Posted on Mar 01, 2013Be the first to answer
2answers
I got a output voltage of 100.1 on a trace dr3624
The rms voltage is what counts, because it tells how much power the output will deliver to a resistive load. Inexpensive multimeters on their AC ranges are usually average-responding rms-calibrated meters. This means they measure the average of the absolute value of the AC component of the signal, and display that average multiplied by about 1.11 (actually, pi over sqrt(8)), the ratio of rms to average value for a pure sine wave. That way, the meter will give the right rms reading for a sine wave.If the signal is a square wave, where the average and rms values are equal, the average-responding meter will read 11% too high.Many inverters put out a modified sine wave (MSW), which sits at zero for a while, goes to a constant positive level for a while, goes back to zero for a while, and goes to a constant negative level for a while to complete the cycle. The positive and negative parts of the signal have the same magnitude and duration. The rms and average values of an MSW depend on its duty cycle D, the fraction of a cycle for which the signal is not at zero. In a well-designed inverter, the duty cycle will be adjusted when the DC input voltage goes up and down to maintain the nominal rms output voltage. If we use peak voltage Vp to mean the magnitude of the positive and negative voltages the signal goes to, then Vavg for an MSW is equal to Vp times D, and Vrms is equal to Vp times the square root of D.The duty cycle for which an MSW will have the same rms to average ratio as a sine wave is 8 over pi squared, or 81%. For any duty cycle less than this, an average-responding meter will read a lower voltage than the inverter rms output, and for a duty cycle higher than this, the meter will read too high.If your MSW inverter is putting out 120 volts rms and its duty cycle varies from 50% to 75%, the meter reading will vary from 94 volts to 115 volts. I avoid the problem by using a Radio Shack 22-174B true rms digital multimeter.
9/1/2012 8:45:22 PM • Xantrex... • Answered on Sep 01, 2012
We are in Haiti, our
Hi, well you see this happened because the "Load" on the Inverter was more than it could handle. You see the Inverter senses the resistance of the batteries to determine how flat they are and how much current to put into the batteries, if anything else is connected to said batteries, that will simply muck up the sensing,and as has happened in your case destroyed the inverter.
I have serviced many inverters and the most likely failure that would emit sparks etc is failed output semiconductors.
One cannot really use an inverter to charge the batteries, like you did, UNLESS the batteries were completely isolated from the Generators wiring, and even then, your inverter, still may not have enough power to do this. As this is NOT what it was designed for.
Really an inverter is used to step up the Voltage from 12/24 Volts DC, batteries to 120/230 V AC.
Now again, one could use it, to then have a Battery Charger plugged into that, and use the output from the battery charger to charge some "Other" batteries, but that seems a bit roundabout.
Yes the Inverter will charge it's OWN batteries, BUT ONLY if that is the ONLY thing connected to the inverter.
8/20/2010 9:40:29 PM • Xantrex... • Answered on Aug 20, 2010
I am connecting the input wires... I know where
I got no where with this site -- so I found the manual for the xantrex (google search) and downloaded the info I needed. No charge!
10/5/2009 12:09:45 PM • Xantrex... • Answered on Oct 05, 2009
When plugged in to electricity the display panel goes to bul then ab5 and the controls flash and the fan runs all the time
is there a switch to switch over from solar to normal electricity
7/11/2021 11:04:07 PM • Xantrex... • Answered on Jul 11, 2021
I hadnever used my Xantrex Prosine 1800i 250/240 V
Unfortunately, if you put AC power on the output of the inverter, you have likely blown the output transistors. Although the inverter can produce AC, they generally do not survive AC from some other source being put onto the output. MY guess is that the inverter is shot, but repairable. Sorry for the bad news. If I were you, I would call Xantrex and see what they say.
1/9/2018 9:56:03 PM • Xantrex... • Answered on Jan 09, 2018
I really screwed up this time! My daughter was
The red light fault you experienced was from the short, which caused an 'overload' on the device. It is designed to shut itself down under such conditions so as to not cause major harm to the unit. It may correct the fault indication after the short is removed (ie: no more playing with electronics when you are not so trained), and the unit should work again. Your mention of the fuses being in a "very tight spot" is typical in most such devices to make them as small and inconspicuous as possible. Working on such devices requires the technical expertise in dismantling and testing, then making needed repairs before again restoring the proper construction. Be very careful because you can damage other components by not handling carefully, and with the proper equipment.
4/20/2017 4:36:02 PM • Xantrex... • Answered on Apr 20, 2017
2answers
When I turn it on, why does it hum for 30 seconds then shuts off due to overheating?
If the output is shorted or if there's a problem in the inverter itself, such as a bad diode or such, then it will do that. Humming beyond a little sound is an indication that it's pulling too much power.
10/16/2015 5:48:21 PM • Xantrex... • Answered on Oct 16, 2015
tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual. E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models. E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units. E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently. E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.? E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation. E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power. E-07 Triac control error Triac has overheated. Shut down unit and allow to cool. E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch. E-09 Spare E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000. E-11 Spare E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1. E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition. CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed. OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
Inverter problems
3K is a big inverter. Depending on mfr, though, inverters put out numbers for PEAK, not AVERAGE Watts, and have trouble supplying large amounts of surge current on demand. Some appliances with large motors present large turn-on demand, like A/C's, washers, ovens, and fridges and will give converters trouble. Your Microwave, if it's a big one, like a 1.2 or 1.3KW will ask for a lot of juice when it first turns on. But once it's on for a few seconds will probably be OK. Get a bigger or different inverter, or a smaller microwave.
8/1/2014 5:44:51 PM • Xantrex... • Answered on Aug 01, 2014
Xantrax xw6048 with 30 each 235w orion poly solar
Yes. That's what that means. 3 strings of series wired panels. Now, the panels are going to be around 30 volts (vmp), so it all depends on the input voltage of that unit. I'd check the voltage range of the charge controller. If it's limited to lets say, 192 volts max for a 48 volt system, you can do 3 strings of 6 panels to keep it under the voltage.This will give you a 4230W panel output every hour, which is substantial.
10/18/2013 8:31:34 PM • Xantrex... • Answered on Oct 18, 2013
0answers
0answers
Xm1800 blown fuse
Be the first to answer 4/21/2013 4:25:48 AM • Xantrex... • Posted on Apr 21, 2013Be the first to answer
0answers
Xantrex Technology DR2412 Inverter / Charger Logo
7 questions posted
Top Xantrex Technology Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Xantrex Technology Electronics - Others
Most Popular Question
got output voltage 100 1 trace dr3624
  • Electronics - Others
