This means the startup folder is either missing or corrupt. You need to use your install disc that came with your mac(or the new system install disc) and hold down the C key until you see the apple logo.
When you get to the install menu, you should see utilities at the top of the screen. Select the disc utility and select the hard drive and click the first aid menu and run the program.
Then just restart and you should be fixed.
If you can't do anything, then you either need to reformat and loose everything, or find someone that knows how to try to save your files.
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
hope this helps
Does the box have an error message?
Which file? What is the name of the file?
