John Deere Tractor Starter 285 345 2243 Lx178 188 Logo
M
Mike Brock Posted on Nov 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to repair pto on 2210 ?
Heard a pop when the pto was engaged, oil leaking around pto
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Nov 10, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
466392
Points
5959
RSG000
Level 1:
New Friend:
  • Contributor 26 Answers
RSG000
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
17576
Points
41
Buy one, take old one off, put new one on. Be careful not to damage plugs or wires while reconnecting. If you cant do this by using common sense then you probably should have a shop do it for you. Its not very hard honestly. Good luck.
1helpful
Husqvarna YTH 150, ID: 954140007; Blades Will not Engage
The seat occupied switch energizes the operator presence relay. This relay allows power to the PTO clutch from the PTO switch only when energized (operator in seat).
A simple test
1.PTO switch OFF
2.Ignition switch to ON position.
3.Engine not runnjng
4.Operator in seat
Pull PTO switch. You should hear the the clutch engage with a notable pop. Then turn off PTO and it will make another pop or clunk when it disengages.
Similarly with PTO engaged, if you rise from the seat it should disengage.
Also a failed charging system may allow the engine to start and run but not provide enough current to properly engage the electric PTO clutch. With engine running check battery voltage is greater than 13VDC.
Chelsea PTO/Allison auto transmission/09 Peterbilt Triaxle. 2 part issue. PTO would start acting up, not engaging or disengaging, I replaced a "plug" underneath and works for while then acts up again
take it in for a proper repair
it is inconvient to have to continually wiggle wires to make it work and time lost is money
you habe identified the problem now tell the repair shop what they have to fix
Pops out of 4wd and pto not working and dif. lock not working
PDF]PTO Popping Out of Gear, How to Fix - N Tractor Club
www.ntractorclub.com/howtos/pdfs/PTO-Popping-Out-of-Gear.pdf
PTO Popping Out of Gear, How to Fix ... If your PTO shift lever does not stay engaged, the problem is probably not in the PTO transmission, but rather is due to ...Missing: 4wd
1helpful
Kubota L 3300 rear PTO will not engage when very cold weather solution please
Try using a lighter gear oil - some oils are thicker in really cold temps - like molasses while its warm drain it and use a lighter grade, - check the manual and go with a thinner type - ask local car parts store. sometimes the manual will give a type for colder weather. Good luck
Loss of Power when PTO is engaged
Something that the PTO drives is defective and placing excessive load on the engine.
May 18, 2017 • Garden
2answers
John deere 2210 engine dies when engaging pto, seat switch good
are you sitting in the seat or have you jumped the safety switch under the seat before you engage the PTO I believe our tractors use an electric solenoid to apply hydraulic pressure to a wet clutch inside the trans axle I would think it would be OK with your chipper I have a 450 tiller that was built for the older 400 models 425 445 455 that I now use with my 2210 If I hit a large root or stone when using it with my old 445 it would stall the tractor at full power. Now with the 2210 it will actually slip the clutch on the tiller s PTO shaft I think the correct approach would be to increase your RPM s gradually or start increasing the power just as you trip the PTO switch. You want enough RPM s to create enough hydraulic pressure to run the PTO circuit so that you don t slip the wet clutch anymore than necessary and you want the RPM s low enough so that you don t shock the mechanical systems too severely at start up
Let me know how it works
Feb 02, 2012 • Garden
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
2answers
Ford 8n tractor.when i put a load on the pto , it pops off
You should repair that PTO system before it gets worse.
Get a repair manual and fix it.
I can't explain the repair here.
Keep in mind.......everything on your tractor is easy to fix.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
