Radio Communications Logo
j
john alan gray Posted on Nov 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DIGITAL S METER READING TOO HIGH WHAT VR POT TO ADJUST
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Nov 07, 2013
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081336
Points
34431
Please follow this steps and fix it. GOD BLESS you
    • 1
Turn on all of the devices in your sound system. Turn off any auto-equalizers on your sound system to gain fullest control over frequencies. This switch might be found on the receiver or the equalizer itself.
    • 2
Play a test song on repeat. Choose a song with both extremely high and extremely low instruments so that you have a wide frequency range to listen for.
    • 3
Listen for any obvious distortions in the highs and lows of the songs. Lower the knob on your equalizer for any distorted frequencies until the distortion disappears. Try at first to find the highest setting possible without distortion.
    • 4
Adjust all frequency ranges in relation to each other to find a pleasing blend for your room, trying not to let any one frequency range dominate the others. Use the highest non-distorting settings found in Step 3 as maximum settings, but don't be afraid to lower a booming bass or a screeching flute that disrupts the overall blend of the music.
    • 5
Play a song from a different genre to test how the EQ works for different types of music. A hip hop song will have louder lows than a string quartet, for example, so make sure your bass frequencies sound crisp on both types of music.
2answers
Where is the modulation pot on the dx 919 v 16
did you use a meter when you set the pot? there are two pots to adjust . one for high modulation and they other for low modulation . Apparently you didn't read the schematic good enough.
Adjust mobility scooter throttle
hi, sadly you can't in most cases, the speed pot is the way to adjust the overall speed ,
You can fit a larger value speed pot hence slowing the scooter down on the lowest setting ...
if you mean the centre location of the throttle pot you must get the slot dead centre to you( meter reading of about 2.5K ) ...when you 're sitting on the scooter...
Regards
Rob
www.gewizrepairs.co.uk
How th adjust peek modulation on a midland 1001lwx cb radio
VR 2 is the pot you are looking for an now you need a modulation meter. Speak into the mic at the volume you will be talking on the radio. One one one one while adjusting for 100 percent anymore an you will begin distorting.
Cobra 1000 gtl modulation/swr meter vr adjustment
you are not matching it correctly. get hold of a friend that knows how to match it and see if he will help you.
How to trun the power up on my galaxy dx 55v
AM CARRIER POWER HIGH: VR-13 pot. for RF power adjust
AM CARRIER POWER LOW: VR-16 rf power adjust
S/rf is too high on transmit on my cobra 29 ltd bt
no matter what s/rf you are looking at it should not key much beyond an s-9 . vr 3 controls the meter. Key the mic and adjust it to s-9 then check you modulation.If you still think you need more then adjust vr 4 .
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
1helpful
Does anyone know the pod too turn for lowering the watts on my connex it is too high and i would like to turn it back also the modulation thanks
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
2answers
SWR meter will not go to cal line.
vr2 is the transmitt signal potentiometer for the meter adjustment during keyup try turning it while keying but use something nonconductive to do so or you could short it..be carefull
1helpful
Audio limiter
tintlady, here is the info you requested;
the AM limiter is R 276
These are the variable adjustments inside,and what they control.
VR-1 AM S-METER
VR-2 SSB S-METER
VR-3 SSB SQUELCH RANGE
VR-4 AM SQUELCH RANGE
VR-6 SSB CARRIER BALANCE
VR-7 TX OFFSET
VR-9 RF METER
VR-10 FINAL BIAS
VR-12 DRIVER BIAS
VR-13 SSB ALC
VR-14 AM HIGH POWER
VR-15 AM MODULATION METER
VR-16 AM MODULATION
VR-17 SSB POWER
VR-18 AM LOW POWER
VC1-10.240 MHz Frequency adjustment
Hope this helps you out, let me know,,Mechanic
Top Magnum Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
