If your LCD is cracked, you will need to unfortunately replace the entire LCD. Simply putting a screen protector (which is just a thin film) will not stop the crack from getting worse. There is unfortunately no magical way to fix your screen other than simply replacing the LCD panel itself, which is totally doable. Many electronics repair shops can fix your TV pretty easily. In some cases, you can even mail it into Toshiba.
Your LCD/monitor is cracked from the inside. There are several things that can
cause a screen to crack from the inside. The two most common are
pressure on the screen or dropping the
machine. Sorry, but it is irreparable. You need to buy a replacement.
The set needs a new LCD if it looks cracked and swirly, the colors all run together in the area of the crack don't they! If it is cracked it can't be fixed. you can replace the lcd but I am not sure if a warranty will cover a cracked screen or not. You will need to contact LG and be very nice to them and see if they will honer the warranty on this.
If you are trying to disassemble the LCD screen and hear cracking sounds then - the crushing/cracking sound is most likely that you have cracked the LCD screen in several places. If you look at an acute angle you will see cracks in the LCD screen.
Replace screens are available at LCD Parts, they supply parts, repair service and DIY info. Use this link to their WEB site. www.lcdparts.net
If the LCD screen is cracked better take it to a service center near you and let them have that LCD screen replace , if its still under warranty that should be free but if not I will still advcie you to have the LCD screen replace it wont cost that much..
