SOURCE: Everything in My Freezer is Melting and Fridge is getting warm!
find another place for all of your food because you may need to call a service company.
possible causes:
stuck in defrost (if nothing is running)
bad compressor (if fans are still running)
freon problem if everything is still running
SOURCE: DS Brain Training how to re set the time or instructions
Have you tried changing the time on the ds console itself?
Try that
Hope this helps
Samantha
SOURCE: I would like to conduct an exam through online
You might wish to consider the possibilities of the free webspace offered by the folks at Windows.Live.com. Have a look at the skydrive feature, which allows you to upload content, make it accessible to groups you define, and restrict it in accord with your preferences. Whether they allow you enough space to make it interactive in the way you describe depends, I guess, on the content you want to post to your space.
Google sites also seems to offer free webspace, though I'm not as familiar with it, you can learn more at https://www.google.com/accounts/ServiceLogin?continue=http%3A%2F%2Fsites.google.com%2F%3Fhl%3Den%26tab%3Dw3&service=jotspot&passive=true&ul=1
You may have to set up your windows system as a server to the website, if you can't write code simple enough to allow the database to function online, but in that case you could trigger downloads with a button of some kind on the site that sent the results to the database. At that point it's a little over my head, I'm afraid.
I hope this proves helpful, and leads you in the right direction.
SOURCE: Hi, we have an Dell PowerEdge
Most of the systems will not start back when the system shutdown happens due to some power conflicts.
To resolve your issue, please follow the below steps:
1. Make sure that all the connections to your server is proper now.
2. Press and hold the system Power ON Switch in your server for more than 20 seconds continuously.
3. now release the power button and press it back gently once normally to start you machine.
4. In this way most of the system will be powered up.
Please follow the above steps and let me know your comments. If still the problem persists, then please provide some more information about the problem which you got in following the above steps as that will be useful to assist you back.
Thanks
SOURCE: sub zero 650
It is the newly adopted power saving technique. There's nothing to worry about it.
