A lock pops up on dash board, then my car cuts off. I have to get a jump to start it up. the jump last for a week, then it do it again.
If the lock looks like this, then the security system is your problem.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
SOURCE: CAR CUTS OFF WHEN PUT IN GEAR
if it is standerd then it is most likely your lutch try to keep your r.p.ms at the owest point you can before shifting if it is automatic it could be the pressure plate but im not an expert with automatics{yet again the change them so often that nobody really is}
SOURCE: Car starts ok then cuts out
HI,HANNAH,I SUSPECT YOU HAVE AN IMMOBILIZER PROBLEM.IF THERE IS A ORANGE LIGHT FLASHING ON THE CLUSTER WITH AKEY IN IT THEN IT IS THE IMMOBILIZER.THE PROBLEM WOULD MORE LIKELY BE THE DATA FROM THE KEY IS NOT GETTING TO THE IMMOBILIZER CONTROL UNIT,USUALLY A BAD CONNECTION AT THE READER COIL ON THE IGNITION.YOU MUST CLOSE THE TERMINALS SLIGHTLY AND INSULATE THE WIRING SEPERATELY.ANDY
SOURCE: ford focus engine cuts out when driving. coilm
Hi, You need to plug this into a code reader and see what codes are stored the most common reason for the engine cutting out is internal fuel pump failure will also cause poor starting
SOURCE: w reg honda accord se cuts out completely whilst
This is a fuel system problem.
Check the fuel pump located in the fuel tank beneath the back seat, and the fuel filter located in the hood.
Rate this.
