Replacing a pull cord is not easy. After you remove the shaft, then the drum cover, you are left with the drum and clutch. There is a screw in the center of the drum which has to come off. Then there is a the clutch which if not removed correctly will come apart on you. Only after both parts are remove can you get to the pull cord.
had replaced rope due to breakage first rope 26 months old
