Hi Kate,sounds like your valves need adjusting,here's a link on how to do it.Here's how you remove the valve cover.
I had a Nissan that started a ticking noise at the front, soon after the timing belt broke. The timing belt should be changed before 100,000 miles All Nissan engines are interference, meaning when the belt breaks valves get bent.
SOURCE: 2005 honda odyssey no low beam headlights
DIMMER SWICH, PROBABLY, WHICH IS INCORPERATED IN CONTROL ON STER. COLUMN?
SOURCE: 2002 NISSAN SENTRA GXE 1.8 POOR IDLE LACKS POWER IDLE FLUCTUATES BETWEEN 1800 TO 1100 RPM
Check for vaccume leaks and also you PCV valve. check the hose too. Visually inspect every vaccume hose you can find. Sounds like a leak .
SOURCE: 2000 GMC JImmy headlights quit working
Check for 40 amp fuse in vehicle but most likely under hood.
SOURCE: Jeep Headlights not working. High beam works
had the same problem on my 92....check under the hood on the drivers side,towards the front,there is a "junction box" with all of the lighting wires connecting from the switches to the lights.My wires were all corroded inside,so I cleaned the ends and bought a new box from the local electronic supply store.The problem has not come back.
Cheers
SOURCE: Audi A4 2002 Low beams & Right front turn signal stopped working
but on 2002 A4, F20 and F21 are empty! Does anyone has an idea where the headlight fuses located?
